Question about Garden
After replacing the flywheel on my leaf blower, the impeller assembly keeps spinning off while I'm trying to start it. Why won't it stay after tightening it down?
Both top and bottom nuts as the flat and lock washers spin off with the impeller. Model #41FR280G034
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 165 Answers
Try disassembling the unit again and when reassembling add some loctite to the shaft when you put the nuts back on. Let it set overnight to dry and then try running it again.
Posted on Nov 09, 2014
Testimonial: "I was thinking the same thing, I'll try that today and let you know how it works! Thanks!"
5 Suggested Answers
wadembly
  • 513 Answers
SOURCE: I have a craftsman leaf blower model 335879770.
you shouldn't have to there are little ears on the flywheel that the starter recoil hits when pulling the handle they might be stuck or not moving when pulling handle
Posted on Nov 10, 2009
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 13, 2009
  • 2239 Answers
SOURCE: Stihl Leaf Blower no top speed model BG86C
If there is a spark arrester in the muffler outlet check this is not blocked with carbon.
Posted on Jun 10, 2012
SOURCE: Replacing the pull cord on
This is from the tech center at Troy-Bilt.......Take the spark plug out and stuff the plug hole with a piece of rope. I used 3/8 nylon,and stuffed it in until I couldn't get any more in....WA-LA!!!!! A few turns with my ratchet wrnch, and I was on my way to success! A breaker bar would be better if you have one.It will save the gearing
Posted on Aug 29, 2012
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
How do I remove/replace the assy-impeller assembly
dis-assemble the blower housing and you will see the required bolt to remove the assy
Dec 12, 2013 | Poulan Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Ho to get to the toro 6.0 magnito
The ignition module is bolted to the front of the flywheel. Im going to assume this is a pushmower and not a leaf blower... Remove the plastic top cover, remove the fuel tank, disconnect the dipstick tube, leave it in the seat but rotate the stay out of the way. Tie the engine kill bail to the handle- run position. disconnect the spark plug wire. remove the flywheel shroud / starter assembly. You will see the flywheel, intake tube and the ignition module right there on top of the motor. Armature air gap is 20 thousandths ( good quality thick business card works good). Set the gap with the magnet faceing the module.
Oct 06, 2012 | Garden
Replacing the pull cord on my Troy Bilt blower/vac (TB320BV), & I can't get the nut off the crankshaft extension, the last thing keeping me from the starter housing. I've tried clasping the flywheel...
Same problem here.After snapping a couple fins off the flywheel trying to lock it with a screwdriver, I had an idea that worked quite well.I used an oil filter wrench (designed like pliers) Item #36778 at harbor freight.The thin design held the flywheel well (very tight fit,had to force past the plastic housing) while I used a socket and power handle.Worked for me and used it when torquing the crankshaft extension nut tight again.
Oct 31, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
My homelite leaf blower UT # UT08023B is running badly all of a sudden. when i pull the trigger to get it to full speed, it acts like it doesn't want to get to full speed only about half speed and it seems...
Its a fuel delivery problem. Its running lean.
Check the fuel line in the tank to see if the filter fell off. If the filter is loose in the tank than the best way to repair is to replace the fuel line. Also the diaghrams in the carb are dry or the screen is clogged. Lastly, if the fuel lines are not rotted and the screen in the carb is clear and everything is in proper working order then you can adjust the carb ( if it has adjustments). Start by turning the low speed needle out ( counterclockwise) 1/2 turn.
Nov 20, 2009 | Homelite Garden
Weedeater pull cord won't pull out on a leaf blower
Suggest to remove recoil housing/assembly and try to rotate the flywheel. Remove the spark plug & check for a silver or aluminum color or coating.
If the flywheel will not turn by hand, the piston/cylinder is seezed. No further repair is affordable.
If the flywheel turns by hand and the spark plug is a dark brown color, then focus your attention to the recoil assembly to see if rope is bound or wound around the rope rotor.
Nov 10, 2009 | Poulan Garden
I have a craftsman leaf blower model 335879770. The pull start doesn't engage. You can pull the cord and it recoils back but doesn't crank the engine. I have it apart but how do I get to the starter pulley...
Nov 09, 2009 | Garden
Homelite yard broom starts a clicking noise then power loss. Power may come back for short bursts and clicking ceases during these times.
Suspect the blower fan is loose on the crankshaft.
Open the housing on the fan side and check mounting nut. If this is the case, remove the nut, apply one or two drops of Loctite-Thread-Locker (in the blue package) to the crankshaft threads and reinstall the nut.
Hope this helps.
Oct 04, 2009 | Homelite 'Yard Broom' Leaf Blower
How do I replace the blower Fan Blade on my HOMELITE blower. How do I hold the shaft to keep from turning while loosening the nut?
you take a screw driver and put it in between the flywheel fan teeth then unbolt the fan bolt for the inpeller
Apr 25, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
