Question about Garden
Yesterday the engine started coming on intermittently when it was resting (usually the sign of a leak) but now the engine stays on even when I turn the on/off switch on the machine to off & now I
Power stays on even when on/off switch is turned off
    Sergeant:
  • 406 Answers
This switch normally makes a contact to ground or chassis also ensuring the switch is or has ground contact
Posted on Nov 26, 2014
  • 7 Answers
SOURCE: oil leak under the engine
If it is a vertical shaft engine then it is most likely the crankshaft seal. That requires removing the engine from the frame and removing the pump from the motor to replace the seal. If it is a horizontal shaft engine then it could be either the shaft seal or the side cover gasket. Both require removal of the pump.
Posted on May 02, 2009
  • 87 Answers
SOURCE: Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
Posted on May 23, 2009
  • 3600 Answers
SOURCE: pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Posted on Jun 22, 2009
  • 174 Answers
SOURCE: Briggs & Stratton engine loses power
Hello herb1007
If it is running it would burn any oil off the top of the piston. (that got there when you tipped it). It sounds like you carburetor needs cleaning. There are sprays on the market that sometime help with this.
Posted on Jul 16, 2009
  • 174 Answers
SOURCE: When I power the Karcher 520M water pours from the
Not too much pressure, a bad gun.
Unfortunately you will have to replace the gun. About $65.00 Canadian
Posted on Jul 25, 2009
02 Honda Civic LX (automatic) randomly stalls while idling at a stop sign or light. Help?
check timing, adjust valve clearance, check vacuum leaks. these are some that need attention.
Apr 14, 2017 | 2002 Honda Civic
I have a 2004 Nissan Xtrail. I have been losing coolant, even though there are no apparent leaks. Now I am experiencing loss of power intermittently, especially uphill, even to te point pf crawling.. ...
Generally speaking, if you are loosing coolant and there are no external leaks, its usually being burned in the cylinders and going out the exhaust.
You can burn a gallon a week and not see any smoke.
You may want to pull the spark plugs and look for signs of a head gasket or intake gasket leak.
Coolant can also weaken the spark plugs and affect the performance of the engine.
Sep 14, 2012 | Nissan Cars & Trucks
Engine sputters in park and neutral but this problem disappears when the ac is running. Any thoughts?
Check for vacuum leaks. Fill a spray bottle with a few drops of d/w liquid and the rest with water. Start and run the engine. Spray around all vacuum lines and areas to where hoses may be going. If the engine r.p.m. increases, that's where your vacuum leak is. Stay away from electrical.
Jul 22, 2017 | 1997 Honda Civic
Hyundai Accent intermittent jerking
Revs.
As for the issue of the idle revs, that's perfectly normal. When it's cold outside, every car is supposed to have a higher rev in order to warm up the engine quickly. In more advanced cars, the computer wont even allow the engine to shift into overdrive when it's cold outside in order to avoid extreme engine stress and damage. When it's warm outside, the engine doesn't need to idle high because the engine is already at a good operating temperature. Not much will be needed to get it to the right temperature.
Intermittent Jerking
There is a long list of things that could cause intermittent jerking. I'm going to name all of them for you, but your best best would be to go to a mechanic and have them do an inspection.
Clogged PCV Valve (Possibly if you don't get your oil changes on time, sign of a tune up)
Bad DIstributor Cap (not likely at 140,000 miles)
Clogged fuel filter (Very likely, usually done with tune up)
Bad Fuel Pump (Not so likely)
Defective ECM (also not likely)
Vacuum hoses/leak (not likely but possible)
MAS (Mass Airflow Sensor--not likely but possible)
Fuel INjectors (if so, sign of a needed tune up)
Faulty Spark Plug Wires (not likely if tune up is recent)
Faulty O2 Sensors (possibly)
Clogged Catalytic Converter (Possible)
~Hope this helps
Jul 29, 2009 | Hyundai Motor 2004 Accent
Emachines , shutting off on it's own?
While it is possible the power supply could be going bad, usually it would not work intermittently like this.
Most likely the motherboard is starting to go bad, I would do a quick visual inspection for any buldging or leaking capacitors, if you see any that is definatly what is causing the problem.
If you dont see any damage to the motherboard you can try replacing the power supply, if it still behaves this way then your motherboard is the problem (sometimes there are no visible signs of damage on e-machine motherboards even when they have completly fried)
Hope this helps :)
Jan 22, 2009 | E-Machines eMachines Desktop PC
Rough Idle, Outside air vent stuck open & Airbag light stays on
I'm pretty sure you would have service engine light on if you had vacuum leak! any how these cars are usually pretty good solid air hoses etc!if you have eng light OBD 2 scan for fault codes don't play the ge$$ing game!don't worry if you have idle problem that engine light will soon appear then scan if you do have air leak you will hear a whistle sound listen closely but keep in mind 10 switches can cause rough idle!air vent stuck open locate the intake park some times rodents make nests!!!seen it before or perhaps cable jumped off?linkage good places to start hope this helped
Jan 15, 2009 | 2000 Plymouth Neon
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Mitsubishi CS31305 TV turns on then goes to snow and then back on
snow basically is a symptom of weak signal.
as you say it becomes ok after 5 minutes or so there no question of any components gone wrong except loose or print intermittent
please check.
1  input weak like cable or antenna or loose wire from the source..
2  in tv antennae socket loose.
3  near tuner any thing loose or track loose.
4  cable wire might be old.
hope this will help.
Oct 09, 2007 | Televison & Video
Crazy turn offs
Symptom: Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Nov 27, 2006 | Hitachi 60V500 60" Rear Projection...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
