Question about Refrigerators
<!-- from fixya rte -->How do I get the doors off for moving - Refrigerators
  • Refrigerators Master
  • 744 Answers
Hello Anita;
My name is Peter. I am a retired field service refrigeration.
I would be more than happy to tell you how to get the doors off.
I need you to provide me with a model number. There are top freezers, side X side, bottom freezers & drawer freezers. Removal of the doors is different depending on what you have.
Resubmit your question with the model number. The model number is on a sticker on the liner wall of your fresh food section
Posted on Nov 09, 2014
I just replaced a a/c heater blower motor resistor and now I have hot air on drivers side and cold air on passengers side and in the rear. .
Sounds like driver side blend door is not functioning, either actuator bad or door has broken, remove actuator see if door moves freely, if door moves freely test actuator, leave out and connect wiring, move controls from cold to hot see if actuator moves.
Apr 23, 2015 | Cars & Trucks
Garage Door: How to fix single car garage door that is in raised position, on tracks but will not move using the power opener or manually?
Gary released the lift could be the rails that the rollers ride on are bent or damaged what you can try is disconnect the 4 panels and try moving top panel inside the rails slots movement to the back and force and see how it works if ok then hook up the next and try it and next try it and next try it this way you can see if one of the panels or the rail is not correct lined up until you have all 4 panels connected again or check with your house insurance and see if they will cover you installing a new garage door system.
Feb 21, 2015 | Building Materials
Why wont my lock move/? I can hear the motor moving but lock doesn't move
Try with your door open. Also be sure that you can operate it by hand. If not, the motor can't move it either.
Facing the outside of the door, if the hinges are on the right, it's a right-hand door.
Sep 03, 2014 | Weiser Lock Powerbolt 1000 Lock
When we open the doors the refrigerator moves
According to how it's moving "away from the wall"; the most likely culprit is balance issues. Does the unit move easily? Is the unit level?
Jul 25, 2014 | Kenmore Refrigerators
Trouble garage door
Disconnect the door so the belt and pulleys will run without a large weight to move. If they move ok, reattach the door and try again but help the door move with your hand. If it moves ok then, the door levers and joints may be too stiff and need lubicating and wiggling until they move freely.
Nov 16, 2013 | Ultra Max Home
How to adjust rear doors onhj75 troopy
the door hinges move in or out to adjust that side of the door and the door lock latch moves to adjust that side.. loosen the door hinges just enough to move the door then -tension them to see how you are going. With the door open and the bolts slightly loose it may be possible to move the hinges by placing a long bar on the hinge past the door edge and hitting with a hammer
Jun 26, 2013 | Cars & Trucks
1998 blazer heat works great but defrost doesnt, could there be a blocked hose and how do i check?the defrost at the front wont blow.
if you have heat and nothing blows on defrost then this is a mode door problem that is not changing from floor to vent to defrost mode.it could be the mode switch or the mode door not working.the mode door is on the air duct under the dash and you can manually move it when you disconnect the control with your hand it should move freely.some of these have a small motor that moves the door.and if you move the switch in different modes or better have someone move the switch while you see were the door is the one that is moving is the mode door.if it won`t move on defrost tap the motor and see if it starts to work.if it does then it will have to be replaced if not it could be a switch problem.
Oct 26, 2011 | 1998 Chevrolet Blazer
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
Seat belt does not move when i opn the door
If only one seat belt does not move when you open door then check the pink wire in the rubber boot passing from the door panel to the cabin around the door hinge, however if it is both seat belts that don't move when their respective doors are opened, the problem is in a little box located right under the hand brake lever, behind the shift lever, of course you have to remove some of the decor to get to it.
Oct 30, 2008 | 1991 Toyota Camry
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
