Question about Dryers
I have a Admiral dryer that wont start. The symptoms were one day the clothes weren't drying properly the next day the dryer wouldn't start at all.I checked the fuse first with an ohm meter that was g
I wasn't hearing anything when attempting to turn the dryer on. No motor hum, nothing. I did check both legs of power were the power cord connects to the machine both sides have 120v. "Confused homeowner" thanks
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 37 Answers
Sounds like you have a blown thermal fuse. This happens when you have a restricted/blocked exhaust vent. Jump/bypass it, if it works make sure to clear exhaust vent or it will blow again.
Also the door switch - not commonI have a Admiral dryer that wont start. The sympto - admiral-dryer-wont-start-symptoms-one#solution-section-p15g0twhbk2df1qsblkfpfhy-1-0.jpg
Posted on Nov 10, 2014
3 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: admiral dryer wont come on
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 02, 2012
TheMobilian
  • 8220 Answers
SOURCE: I have an admiral dryer that has now power when the start button is pushed. The breaker is good. I replaced the door switch, high limit switch and thermostat , still know power.There is know buzzing a
That must be the motor is bad if you have already detirmined the fuse mounted on the heater is ok. Buzzing usually indicates a motor poling out.
ADMIRAL DRYER SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 05, 2012
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Admiral dryer wont dry clothes
one of several things can cause this . contacts in the timer , heating element ,door switch to name a few .plugged lint filter also can cause poor drying as it slows the air flow .when all else fails call a service tech
Mar 13, 2015 | Admiral Dryers
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here https://www.youtube.com/watch?v=tVc6SZ2DD4U
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
If an "Admiral" dryer stops getting warm or hot, wouldn't it be the hot/warm selector switch?
it could be the element burnt or restricted venttube or maybe even a burnt wire from the pigtail take the cover off where the pigtail goes into the dryer and see if one of the wires burnt
Jan 08, 2013 | Admiral Dryers
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
The pilot light isn't on and wont light up, no smell of gas either. The dryer was working normal I thought, open the door and the clothes weren't dry.
You will need to replace the Thermocouple. You can purchase one at your local hardware store, the instructions will be with it. Very easy to repalce.
Sep 14, 2011 | Maytag MDG7600AW Gas Dryer
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer doesnt work
check the door swich to be sure made up properly
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
