Question about Flotec Plumbing
PRIME FILING LOCATION
3 DAYS WITHOUT ELECTRICITY--POWER CAME ON BUT NO WATER. NEED TO PRIME??
  • Joel Fluth
    Joel Fluth Nov 08, 2014
    Hi ROBERT MODERY, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? I assume this is a jet pump? Does the motor run? Could there be a low pressure shut off switch on it? That kind of switch would have a little handle on the side to hold switch in on position until minimum pressure is created. It is a safeguard to save a pump if you run out of water. If pump runs and priming doesn't help, try taking pump apart to see if debris is lodged in the nozzle.
I wish to cancel my Amazon 30 days free trial
There is this thing called Google :>)
Amazon.com Help: End Your Amazon Prime Membership
https://www.amazon.com/gp/help/customer/display.html?nodeId=201118010
  1. Cached
To cancel an Amazon Prime free trial, click Do not continue. ... company (such as Sprint), please reach out to that company to manage your Prime membership.
3 Ways to Cancel an Amazon Prime Free Trial - wikiHow
www.wikihow.com > ... > Shopping Online > Amazon
  1. Cached
  2. Similar
Amazon Prime is a membership-based service that provides free 2-day ... If you are still within your 30-day free trial, you can cancel without your credit .... I need to know the amazon.com telephone number to cancel my free 30-day account.
Amazon.ca Help: End Your Amazon Prime Membership
https://www.amazon.ca/gp/help/customer/display.html?nodeId=201514690
  1. Cached
  2. Similar
If you are currently in the first 30 days of a 13-month membership in Quebec, click Do Not Continue. ... Note: If you are not a resident of Quebec, at the end of a free trial period, you'll be ... You can use the instructions above to cancel at any time. ... Shipping Rates & Policies · Amazon Prime · Returns Are Easy · Manage your ... cancel my Amazon 30 days free trial Google Search
Feb 24, 2017 | Amazon Computers & Internet
Rear driver side heard freeze plug replacement.
It is impossible to propose a diagnosis without knowing the YEAR, MAKE and MODEL of your vehicle.
That being said, replacement of freeze plugs on any vehicle is not a minor undertaking. The mere failure of a freeze plug suggests poor maintenance of the vehicle over time, and is often a precursor of additional underlying cooling system damage.
To replace freeze plugs, often the engine must be removed, or at least decoupled from the car and elevated, to access the freeze plug location. Once you have access to the freeze plug location, you need to pry out the existing freeze plug, removing all rust deposits from the visible cavity and filing the freeze plug seating surface smooth, then use a mallet and large wooden peg to install the new freeze plug.
Once you are done, it is highly advisable to replace the thermostat in the vehicle, check the condition of the radiator, and be certain to maintain a 50/50 ratio of antifreeze to water, using only filtered water.
May 21, 2015 | Cars & Trucks
My 4yr. Chihuahua has been eating fine, refuses water,has not pooped or urinated 2 days.cries when she shakes her head little as if an ear ache? Doesn't want to play - walks like bound up.
Could be pancreatitis but you NEED TO TAKE HER TO A VET ASAP.
The rule of threes, 3 weeks without food, 3 days without water, 3 minutes without oxygen -- not always precisely lethal, but very, very often will cause life-threatening complications. In the case of water, after 2 days without it she is on the verge of renal failure AT THE VERY BEST.
Regardless of the cause she needs supportive therapy in the form of IV fluids, or she will die. Unless you have some Lactate of Ringers on hand, and the skill and supplies needed to administer you'll need a vet. It's that simple.
Dogs are the finest friends a man will find in this life. I wish yours the very best.
Jun 26, 2014 | Cars & Trucks
I have c7 code
it is a communication problem between remote control and tankless unit
Temporary fix:
1 Turn off electricity to tankless and remove cover. Find two terminals that remote control connects to.
2 Disconnect remote control wiring. Turn electricity back ON.
3 Open hot water tap and see if unit works as expected.
4 Without remote, tankless will heat water to default 120 degrees F and will run without the remote.
Contact Rheem they may send you another pcb board.
Nov 11, 2013 | Rheem Paloma Tankless Water Heaters...
I have a Milwaukee paint sprayer that will not prime and stay primed. If I work with it I can get it to spray water sometimes and never paint. I tried to prime with it and had to water down the primer to...
I had the same problem. Turned out to be the hose clamp was loose and it was sucking air. I did not find the problem until I connected the garden hose adapter and pressurized the line. After the line was pressurize water was sqirting out at the from the hose connection on the right angle connected. Tighted the clamp and it primed without issue.
Sep 17, 2012 | Air Tools & Compressors
There are 3 houses each have to be be connected to the gas co, the electric co and the water co without the connections crossing paths
It is somewhat confusing with the information provided. So, 3 houses, and you need to have the gas, water and electricity come into the house without these 3 utilities crossing each other. I am an electrician and I can give you this solution from my experience. I rather like to have all the utilities enter a house at the same location. This gives me an area in the house where I have everything including telephone and cable enter and this allows me more space in the house because the utilities are not taking space in other rooms. So, water is usually installed from about 8 feet down in the ground. Electrical can be buried at 3 feet and the gas is the tricky one. The thing with gas and electrical is this. If you cross a propane line with electrical the electrical must be above the propane line by a minimum of 1 foot. Propane is heavier than air and will flow down in to a trench so electrical is above. If crossing natural gas, then the electrical is below the gas. Natural gas rises. Water is not a problem for either. I would check with local regulations for exact measurements and procedures.
Mar 08, 2011 | Garden
Shallow well pump every two days losing its prime it takes five cups of water to re prime
You should have a check valve installed on the incoming water line ( suction line) of the pump. This should keep the water from leavin the pump. if you still need to prime then there is a leak on the incoming line from the ground to the pump and you will need to have a well company come out and install a new line.
Sep 15, 2010 | Plumbing
3/4 Whisperflo will not prime
once you figure out why it's having trouble priming, you can reduce the discharge side with a valve to adjust the flow to what you need. You can always always reduce the discharge side but never the suction side.
Jul 01, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Is amp any good after being in the water?
Sorry, not very likely. The water causes electricity to run in areas it is not supposed to and usually destroys the unit.
A possible solution,
if the power has not been applied,
if the power was not on when it got wet, ever,
if it is less than a week since it got wet,
the unit could be taken a part, washed with clean water and a soft brush (Don't damage any small parts!) Dry the BARE circuit board over a home forced air vent for two or three days, then reassemble with new HEATSINK compound and try it. Chances are 20% it will work.
Modern electronics does NOT like water.
Mar 21, 2010 | Jensen PS2130 Car Audio Amplifier
Plumbing Logo
52 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
