Question about Water Heaters
How do i replace a broken grommet
Grommet dried out and cracking
    Problem Solver:
  • 9 Answers
Use a small curved pick to get the remains of the old grommet out.
Try McMaster Carr for a selection of new grommets.
Posted on Nov 26, 2014
  • 81 Answers
Measure the diameter and put that info into goggle or yahoo or bing or other.
Unless the inner - open - diameter is an odd spec it should be easy to find
Posted on Nov 11, 2014
Cracked radiator
Bottom line, any radiator leak repair in the coolant is temporary if it works at all. It the radiator is leaking/cracked, you should replace it soon before you're stranded somewhere.
Mar 24, 2014 | K-Seal ST5501 Multi Purpose One Step...
I had a shower total replacement less than two years ago. Company out of business now. Shower grout has cracked bad at base and in corner all the way down. I need to re-grout. Problem is the gap in...
Try using a small amount of thin set, Troll it in and be sure to leave a small gap. Let it dry and then use a high quality silicon caulk. Be sure to let that dry for at least 48 hours.
Good luck,
Marty
Jan 21, 2013 | Whirlpool Water Heaters
The bottom heating element keeps blowing breaker and bottom of heater is filling up with water around heating element
If there is enough water around element and lower thermostat, it's going to blow the breaker. If you don't have leaks at the pipes above, it's probably time to replace the heater. If the leak can be found and repaired, there may be hope for the heater but, if it is leaking past thermostat, you probably have a crack in the threads. Make sure, if your going to work with the wiring of the unit, that it is turned off and, if it is on, make sure you're careful and not standing in water. You could quite possibly have a cracke or broken tank.
Jun 25, 2011 | Rheem Water Heaters
Not getting any hot water. Pilot light and burner seem to be working properly. Went from working fine in morning to not working at all this evening.
No hot water anywhere,or just one faucet,doesn't sound right if burner is working,if its coming on then your gas valve/thermostat on front is not working properly.Can be changed,but I would turn up temp. red dial see if she fires and watch to see if she stays on.Gas valve is threaded in and can be changed,depending on warranty.Could also be dip tube is cracked or broken in half,its a tube that forces cold water to bottem of tank,if not working you'll get a real short shower because cold water is in top of tank.Tube can be replaced,its on the cold water fill side which would have to be taken apart.Thinking now its your tube
Jan 27, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water is putting the burner out
if you check the bottom of the tank or there is water on the floor constantly..check the top of the tank most of the time the shut off valve is leaking or the hot cold connection on the top is leaking..if both these are dry then there could a crack in the tank
Jul 05, 2010 | Rheem Water Heaters
Cracked water heater
Clean the crack up and expose clean metal by sanding it or a small grinder. Use JB weld it is a two part mixture that set's up hard as steel. Any hardware store should carry it.
I have fixed gas tanks,glasses and a few other thing's with it.
The main thing the surface has to be clean so the compound get's a grip to the metal. Since you already have a crack the compound will go into crack to get a inside bond.
You may use a small file or sand paper to open up the crack a little by adding a bevel to groove to expose shinning metal to get acurate bond.
Drain tank and let it dry out before attemping to fix.
They make all kind's of JB weld for different types of applications and Lowes or Home Depot will carry it.
Check out this link http://jbweld.net/index.php
Jun 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
My Rinnai R85 heater will not heat; it is leaking water. I installed the unit 24-26 months ago, and had no problem until today. The automatic starter will engage but the flame (pilot) will not ignite. The...
I just fixed a leaky R85. Fortunately it's the bypass valve, not the heat exchanger. Did your heater freeze up in this snow storm? Unplug the power, open the cover and see where it leaks. If water comes from the top, means crack on the heat exchanger, then it would be too costly to replace. If you can see the water gushing out of a valve, on the bottom of the heater, then it's an easy fix. The valve is fixable, you don't have to replace it. But still need to find out what causes the flame fail (error 12). I suspect the igniter got wet, dry it with a towel after you take out the valve. Removing the fan first will give you more room to work inside.
Feb 09, 2010 | Rinnai Digital Remote Water Heater Control...
Water leak at top rheem 21v40s-2
you need to replace the water heater, the tank is cracked and under pressure so it is forcing the water to the nearest opening
Jun 03, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Potterton Profile 60e doesn't start first time
could be fan speed or air pressure switch-is case seal sealing properly also check grommets under boiler for blowing.
YOU CAN ONLY WORK ON BOILER IF YOU ARE GAS SAFE REGISTERED.
Apr 04, 2009 | Water Heaters
Water Heaters Logo
135 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
