Can settings affect TV off power after some mins
    Top Expert:
  • Televison & ... Master
  • 74,630 Answers
If off-timer settings is set; the TV will shut down after that time. Keep this settings to 00:00; to work the TV continuously without any halt. Refer its user manual for details.
Electro help
Posted on Nov 08, 2014
I have a 62 inch Panasonic Plasma that I inherited from a friend (it was apparently going to cost $800 to repair). It worked perfectly for a week, but since then it has continually switched itself off...
it sounds like a power supply problem, not anything you have done.This day and age the new electronics are only built for min running requirement, as in the working capacity of the power supply.
It has a standby mode thats why most things have a led to show you if its on or off. so you can have instant picture, if you have turned this type of teleivision off at the wall it would take a few minutes to get a lets say a stable picture.
But this means the the powersupply is only in sleep mode only and uses bare min, to run and when you push the power on button you have life and then your picture.
Try this if and when it comes on and stays on, then it goes off on you, turn it off from at the wall and leave it for 5-10 min and try again, if it comes alive its a heat problem in the supply and maybe a dry joint which needs to be looked at.
If it does not try turning off and on at the set not at the remote, it could be the remote section is not working properly and have the same sort of fault. If you think it could be in the set up, try your sleep mode set up, it could be turned on, so check if the TV goes off at the same time say 5 min's everytime??
If it's the first fault you will have to get it back if its still under warranty very quickly, these are inherent problems, c.
if its the type where you have a power lead that plugs into the set and the wall Check that too, hope this helps
Sep 25, 2008 | Televison & Video
TURNS OFF AFTER 12 MINS. SLEEP IS SET AT OFF
In addition to a Sleep Timer, many TVs have an Off Timer, too. Check for other automatic settings and timer settings. If you use the TV as a monitor for a computer, the sleep setting on the computer might affect the operation of the TV.
Apr 28, 2015 | Televison & Video
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
Won't power up sometimes. Same with using the remote.
your tv sets had encountered internal power supply failures. please contact your nearest tv repair shop.
regards, lucgalman
Oct 09, 2009 | Televison & Video
Sanyo Vizon T.V. No sound, no pic
No,this is the internal hard ware power supply problem
Jun 01, 2009 | Sanyo DP32746 32 in. LCD Television
Bad static on toshiba
I believe your problem to be somewhere in the tuner section. That's why it affects both sound and picture. Could be a bad solder joint or component in that area.
Greg.
Aug 13, 2008 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Power
  • Sorry but it can't be fixed without knowing how a tv works on the inside. The problem is on the inside possibly in the horizontal section and should be taken to a repair shop
Dec 31, 2007 | JVC AV-32730 TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
