Question about Apple MacBook Mac Notebook
How do i fix filter problem
Will not print refers to filter error
  • 22 Answers
You didn't provide much detail, so bear with me for awhile. There are a number of possibilities.
Gmail
It may not seem intuitive. First of all, are you able to login to your alternate email, you needed one to setup Gmail? The reason I am asking this is that the first thing to check is that your password is not correct. Remember that Gmail's password is case sensitive, so double check that you have entered it correctly.
Next are you able to read/send/delete/archive your Gmail from a browser? To troubleshoot this, if you don't have the Chrome browser, get it. In the Chrome browser, at the initial screen, click on skip for now. Then go to https://www.gmail.com. Are you able to login to Gmail? If you can login to Gmail from the Chrome browser. If your password is incorrect, and you don't remember it, you may request it to be reset and the new temporary password will be sent to your alternate email, so you'll need do access that account to read your password and the instructions to using it.
Once your password is correct, or you are able to get in to Gmail in Chrome, you'll need to confirm a couple of settings in Gmail. Click on the gear, and select Settings. Along the top you'll see several settings, select Forwarding and POP/IMAP. Next, ensure that POP is disabled and IMAP is enabled. If that is not the current setting, change it. Click on Disable POP and click on Enable IMAP. After making those changes, you MUST click on the Save Changes button. If you miss that step, it won't change.
Mac OS X Mail App
Now everything is setup correctly in Gmail. The next is in the Mac OS X Mail app. In the Mail app, select the Mail menu item and go to Preferences... then select Gmail or whatever you called it. There will be three tabs shown. Select Account Information. Then in there, make sure that your Email Address is your fully qualified Gmail address, meaning <user id>@gmail.com. Then, go down and make sure that the Incoming Mail Server is set to imap.gmail.com. Then the Outgoing Mail Server (SMTP) is set to Gmail. TLS Certificate should be set to None.
Now go to the Advanced tab. Then make sure all the top half check boxes are checked except make that the Send large attachments with Mail Drop not selected. Leave the IMAP Path Prefix blank. Then make sure that Port is set to 993 and that Use SSL is checked. Also that Allow insecure authentication is NOT checked. Check the Use IDLE command if server supports it.
Now close that Accounts pane and close and restart Mail. It should already connect and be on-line, but just to be sure, restart Mail.
This should solve any setting issues. Let me know if you are able to login via the Web Gmail, via the Chrome browser but it still shows as off line in Mail.
Posted on Nov 28, 2014
  • ManoaHI Nov 28, 2014
    I posted answer to wrong question. Sorry.
Lexmark 5150 has stopped printing. press print and get error code0502 how do I fix the problem
The 0502 error code can be caused by either faulty cartridge or a dislodged encoder strip (transparent strip) in the cartridge area. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display. This will help you determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X5150 All-In-One InkJet Printer
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
ERROR 5100
you have a carriage error thats what the error code refers to.
can depends on a lot things but usally not worth fixing if its done lots of prints
canon tech
Apr 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Won't print
Ink system has failed. Unable to print. Refer to printer documentation. Error:Oxc18a0101
Mar 29, 2009 | HP Office Equipment & Supplies
Print unable 30 & print unable 50
I had the same problem. I got a sledge hammer and hit it till there was nothing left. Then I bought a new printer. Takes the frustration out of the fix
Jan 26, 2009 | Brother MFC-5460CN All-In-One InkJet...
Apple MacBook Mac Notebook Logo
130 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
