Question about Technics Audio Players & Recorders
Cd mechanism not turning
Mechanism not turning
  • Technics Master
  • 5,533 Answers
Blown fuse!
Posted on Nov 08, 2014
It turn completely off while i was driving while in off posision than 1 cd came out after all mechanism sounds stopped it turn off cannot turn back on. I pressed the reset button, 1 cd came out, all cds...
I'd guess you have a bad power connection to the device. Check connections for corrosion. Scrape to bright metal, make sure the connections are tight.
Mar 26, 2015 | Miscellaneous
The cd holder wont open
There's a possibility that the somewhere within the CD changer's mechanism there is something jamming the gears which allow it to open. I remember there was one time the CD changer wasn't opening and it turned out a cd was under in the CD changer's mechanism and I have no idea how it got there. In order to fix your problem you'd most likely have to open the unit and take the CD changer out but don't be afraid, opening and operating on this system is pretty much straight forward.
May 14, 2014 | RCA RS2663 Shelf System
I have a cd stuck in the stereo that refuses to come out. Please give me advice on getting it out.
TRY TURN OFF CD PLAYER.WAIT FOR ONE MINUTE.TURN CD PLAYER BACK ON PLAY CD AGAIN THEN TRY REJECT IT AGAIN.DO THAT COUPLE TIMES.TURNING ON AND OFF CD PLAYER WAITING MINUTE WILL RECALIBRATE IT.IF THIS DONT WORK GO BY BMW DEALERSHIP CLOSE TO CLOSING HRS WHEN MECHANIC NOT BUSY ONE WILL REMOVE CD FOR YOU.
Mar 09, 2011 | BMW 325 Cars & Trucks
I put the cd in tray 2 bu ti may not have placed it right and now none of the trays are opening and its acting wierd when turning it on
Seems you may have caused the mechanism to become mis-aligned by putting in the cd wrong...you may need to have a tech realign it at a shop..or, if you mechanically inclined, you can obtain a service manual for it and try realigning the mechanism yourself
Jan 08, 2011 | JVC MX-GT700 CD Shelf System
What can i do when my cd gets stuck in the cd player and wont come out
You'll need to take the stereo out of the dashboard. Unplug stereo and remove screws holding cabinet to the guts. Remove top of cabinet so you can see the cd and mechanisms inside the unit. Replug in the unit and push eject, watching mechanisms on both sides of the cd carrier to see if one is moving faster than the other. If eject works then you may have an alignment problem with the stereo - it's possible that you may have just fixed that too, so re - insert cd and immediately eject to ensure proper operation of the mechanism.
If cd does not eject, get a small bladed screwdriver and manually turn the gearing on the side of the cd tray, going from side to side until you have proceeded far enough to pull out cd. Now take the stereo to a repair shop for estimate - or buy a new stereo to install, depending on the cost of the one you're having trouble with!
Nov 16, 2010 | Pioneer DEH-P4000UB CD Player
Remove a CD
It all depends on what has happened to your player. If stuck within without any power, repair the power supply before you get this out. If the mechanism had jammed due to a badd cd then slowly turn the motor drive to eject. If motor mechanism if faulty reset, if motor drive is fautly check for voltage and replace the drive. Sometime resetting of the set can make the struck cd released. Since I am not told of your make model and exact fault , I cannot give more details. Hope you get this right. Good day
Jul 20, 2010 | Sony Audio Players & Recorders
The cd disk ia stuck
Unplug unit from AC wall socket for minute or so to get it reset, replug it and turn it On that might reset CD mechanism and stuck CD come out.
If that does not solve the problem, CD mechanism will be inspected for any gear damaged that causing problem. You may be need tech to fix it.
Thanks.
Nov 29, 2009 | Sony DAV-HDX500 System
Error 11
it simply means it fails to complete the self test program upon power up. This could be most mechanical, a miss aligned gear, loose or dropped drive belt or foreign material accidentally dropped inside. Opening the cover and examin the mechanism may just spot the problem.
Jan 07, 2008 | Pioneer CDX-P670 6-Disc CD Changer
CD tray repeatedly opens and closes
is this a yamaha 5 disc changer, table. not the cartridge type...
Aug 02, 2007 | Yamaha CDC-502 5-Disc CD Changer
48 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
