Question about Binatone 100 Latitude Walkie Talkie twin Blackyellow
How do l stop strange tone about every minute
New batteries constant every minute on 1 or other handset tried different locations same
  • Dale Lee Jones
    Dale Lee Jones Nov 08, 2014
    Hi Mark Pearce, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
My GE cordless phone Model No. 28112ee3-a is not functioning and it keep beeping. I once found a code to stop it from beeping. can anyone help?
The GE 28112EE3-a was made by Thomson with the GE name. The manuals for most of these phones are available here: http://www.home-electronics.net/user_guides.asp . The direct link to the manual is http://www.home-electronics.net/USER-GUIDES/28112_DOM_EN_CL_IB.pdf .
What type of beeping are you hearing? If you are hearing a beep every seven seconds from a handset, the solution is to recharge the battery. If the battery won't hold a charge, then replace the battery with a 5-2721 Nickel-metal Hydride battery.
The handsets can also beep for about 2 minutes if another handset or the base pages them. This is a locator tone. Just press the Talk/Call Back button or the Tone/Exit button on each handset.
I hope this helps.
Sep 21, 2014 | Thomson GE Cordless Telephone 27995GE1
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Portable hand set will not hold charge longer than 10 minutes.
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps are worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Mar 16, 2009 | Panasonic KX-TG5230M FHSS GigaRange...
Phone getting switched off when speaker is turned on
(Just received this from Panasonic Support...Thanks Panasonic!) The following might be worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Dec 21, 2008 | Panasonic KX-TG4321B Cordless Phone
PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Apr 02, 2008 | Uniden Cordless Phone
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Constant tone on an HT1000
You will get a constant tone on any channel that isn't programmed. it sounds like the previous user ha a freq programmed on channel 1. Channel 11 is strange, but possible. Usually guys program these radios in order.... they don't put 2 freqs in soo far apart from each other..... I would expect channel 1 AND 2 to have freq programmed in them.... but channel 1 an channel 11 is strange... but possible. Anytime you don't fill up all the channels on these radios (commercial radios in general) you will get a constant tone on the channels that don't have anything programmed in them. Program the radio and your good to go. If you don't program freqs into al the available channels, expect to hear that "constant tone" on any unprogrammed channels. The channels that you hear a tone on do not have a freq programmed into it. Its normal. Good luck
Jul 05, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly? please let me know. Good Luck
Mar 01, 2006 | Xact Communication XG2200 Cordless Phone
Binatone 100 Latitude Walkie Talkie twin Blackyellow Logo
67 people viewed this question
Top Binatone Radio Communications Experts
ray gallant
Steve
Steve
Are you a Binatone Radio Communication Expert? Answer questions, earn points and help others
