I have LANIER LD115 Copier/ printer can not copy and print ,red light showen on copy button,Erro shown " SC: 544" AND " CALL SERIVCES" , GREEN Light on copy indicator, red on printer light, shown up
Can not copy or print
  • 1,169 Answers
The copier error code SC544 / 544 is a fusing lamp overheat error code. (This is a hardware problem)
This error can mean the:
PSU board is bad
IOB board is bad
BICU board is bad
Defective thermistor in the fuser
Defective power supply
You need to contact a local service technician to take a look at your copier.
Posted on Nov 08, 2014
gwbm
  • 353 Answers
SOURCE: epson stylus c42 plus
If both red and green lights are blinking, it usually means that your waste ink pads need replacing. This requires dismantling of the printer and resetting of the protection counter. If you feel up to it, respond with your e-mail address and I will send you instructions - but it's not easy.
Posted on Jan 31, 2009
angelus316
  • 41 Answers
SOURCE: I have a Lanier 5245. I am getting an error when
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
Posted on May 22, 2009
SOURCE: prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Posted on Jun 13, 2009
itsourcer693
  • 34 Answers
SOURCE: Printer stopped printed and error message came out
It's 100% a cable problem. Do you have a rep in the area?
Posted on Jan 05, 2010
  • 26 Answers
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
Posted on May 20, 2010
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
I have a Ricoh copier 1018 D, when I make a copy of a document it comes out with faded prints at the bottom (3 or 4 lines)
i have a ricoh copier but is is showing SC 320 erro call for services please what is that code, help me.
Feb 17, 2011 | Office Equipment & Supplies
Sc 544 lanier ld 122
May 17, 2010 | Office Equipment & Supplies
May 08, 2009 | Lanier 5235 Printer
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Only prints once ?? Toshiba BD-3810
When the toner is very low the copier is programmed to only print one copy.
Fill the toner and it should go back to normal
Dec 05, 2008 | Office Equipment & Supplies
Lanier 7213
Is the copier displaying any numbers or letters besides a service call light. The copier will display more then you are telling. Need a little more info. to give a educated answer or do you want a SWAG answer?
Mar 11, 2008 | Office Equipment & Supplies
Lanier LD032c Photocopier The red spanner light is on and the screen is stuck on 'downloading, please wait'. If you could suggest a way to fix this as we have turned the machiene of to reset and it still...
Try a software reset which involes holding down the * and # (next to the 0) buttons for about 10 seconds until you hear a beap. You should then see "Now loading. Plese wait" and it should start up normally.
Its possible the machine has just locked up. If the above procudure dosen't work power off at the power piont and leave off overnight.
Please advise if any SC codes are present with the spanner for further help.
Feb 05, 2008 | Lanier 1205 Copier
140 people viewed this question
jasbo
jasbo
