Question about Wharfedale Televison & Video
I'm looking for the manual for the Wharfedale DVD-75USB Home Theatre system. Can anyone assist?
Problem with Wharfedale Modus One-Six Speaker I am looking for a manual for the Wharfedale DVD-75USB Home Theatre System. Please can you assist S/N V10611001804 Power Source AC-220-230V / 50Hz Not sure if the above product name is correct. My system has 4 little speakers, 1 a little larger rectangular in shape and a subwoofer. It is HiFi + DVD/CD player. I require a manual for this as mine has been mislaid and I do not know how to use it.
SOURCE: charger
www.pclaptopgarage.co.uk
Posted on Dec 19, 2007
SOURCE: wharfedale dvdr24hd160
have you try a multy scarts socket , available in many stores , argos , currys, dixson ?
Posted on Jan 09, 2008
  • 76 Answers
SOURCE: AVIA Speaker System and DVD Player
I'm not sure how much you could sell it for but If you contact the manufacturer they would most likely send you a copy of the owners manual and if they won't you can usually find a PDF copy of it at the manufacturers website. Hope this helps. =)
Posted on Feb 25, 2008
  • 10 Answers
SOURCE: Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: warfedale dvd
I don't have a service manual, but IC2 is a 1200P60, datasheet can be found at http://pdf1.alldatasheet.com/datasheet-pdf/view/115078/ONSEMI/NCP1200P60G.html
Posted on Aug 24, 2009
Adjust treble
is it too much treble and you want to attenuate?
if thats the case i have a simple suggestion. wire used for doorbells has no place between an amplifier and a speakers. you could try obeying for a set of modus cube speakers. they're great and cheap. between 10 and 25 GBP a pair. you may even be able to find the centre speaker. if not just get 6 speakers or 3 pairs. use 5 of the 6 and keep a spare. wharfdale modus cube main speakers
or Wharfedale Modus Cube Main Stereo Speakers
theres 2 sets easy to find.
Apr 11, 2014 | Sony DAV-C700 System
How do i connect Wharfedale 9.5 speakers to onkyo HT- R538 home theatre system
Take a look at the setup procedure. Your Onkyo may allow you to select speaker size and distribution of bass, etc
Dec 26, 2012 | Wharfedale Audio Players & Recorders
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
Is the tweeter a stand alone 8 ohm speaker?
yes, but it is attached to circuitry that allows only the high frequecies into it. You can replace the speaker with any 8 ohm tweeter without any difficulty, but if there is a capacitor across or in series with the speaker, make sure you put it on you new speaker the same way.
Mar 20, 2011 | Wharfedale Modus One-Six Speaker
I just brought some wharfedale one-three speakers and have them hooked up as the rear speakers. Can i get the sub to play still and do i hook the speaker wires in the top or bottom?
Do you mean "Modus 13"?
See picture 6...
http://www.freeads.co.uk/uk/av/audio/hi-fi/speakers/8402337/wharfedale-modus-one-three-speakers-black-rare-bi-wire-quality/view
Put the jumpers back in as shown. Hook your speaker leads to either top or bottom. The entire array of drivers will be active.
Make your receiver aware they are LARGE for the purposes of bass reproduction so some bass will get out to them. FYI, many AVR's will only allow Large Rear speaker selection if you also have Large Fronts. Refer to the manual(s).
Mar 07, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Ok..... I have some Wharfedale Modus 8s. My question is, is that the base speaker is crackling a bit. typically when you don't have enough power the tweeters will clip first and go out. perhaps i did...
Dunno how old they are, but I just had an 11-year old pair of woofers re-edged because the foam surround and the adhesive had deteriorated. Upon close inspection the foam surround was noticeably pulled away from the cone in a few spots. Unfortunately, if there is an age-related issue with materials beneath the surface that you can't see, you'd have to pull the driver to check it out.
It wasn't until I turned my bass up loud that anything sounded wrong, which precipitated looking for the culprit (quickly found).
Nov 08, 2010 | Wharfedale Modus One-Six Speaker
I need to buy one Wharfdale Modus 8 speaker only.
Hi.
I have this modus 8 in good condition want to sell it if you wish.,
my email: devizal@cbn.net.id.
locatd at jakarta,indonesia
my mobile nos. (62) 816-809066
cheers
Apr 18, 2009 | Wharfedale Modus One-Six Speaker
Modus one six speaker not working properly
Hi. If you have an digital multimeter to hand you could always drop the drive unit (the metalwork with the paper cone) out from the enclosure and make sure the resistance of the voice coil is between 4-16 ohms. If there is no reading then the voice coil could be open circuit and the whole drive unit will need to be replaced. If the others rattle check the mounting screws are not slackened off. Especially if you have been driving them hard!
Dec 23, 2008 | Wharfedale Modus One-Six Speaker
Modus One Six spare parts
You may want to check ebay, they sometimes have drivers for sale. Additionally, I would contact IAG (International Audio Group). They are the distributor for Wharfedale here in the states and may be able to help you. I also have the modus one-sixes, modus-two's, and modus center and was albe to get replacement parts from IAG, never needed a driver though. How did you blow it anyhow, these speakers can take a beating, are you using a quality amp? Underpowering the speakers and trying to drive them loudly = demise for your speakers.
May 03, 2008 | Wharfedale Modus One-Six Speaker
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Jan 15, 2008 | Wharfedale Modus One-Six Speaker
Televison & Video Logo
44 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jonathon summesfield
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
