Question about Pool & Spa
I too have spent all day trying to get the Hurlcon Viron Pool Heater to operate and the F2 fault keeps appearing. We have had this problem before and had to have the Temperature Sensor relaced at con
This will be our 3rd service call out on the same heater in 2.5 years. Same problem each time - corrosion of a Pressure-Temp Sensor component that can easily be made in a more corrosion-resistant material. Astral should act - we are reluctant to install such a heater in our new house.
  • Paul Gear
    Paul Gear Dec 31, 2015
    Can you recommend a repairer in the Newcastle area. Contacted Hurlcon in Syd, but have not received any response.
    Genius:
  • 2,494 Answers
Change it a gain
Posted on Nov 08, 2014
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
  • 4 Answers
SOURCE: lpg spa heater cuts out at 86 degrees....
Is this an indoor heater? Vent could be blocked.
Posted on Dec 04, 2009
thepool
  • 78 Answers
SOURCE: Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
Posted on Apr 23, 2010
Hurlcon MX 250 Pool/Spa heater. Why does it have an intermittent F2 alarm (high temp >45d)?
check the manual bypass inside if ok check the temp sensor also check gas pressure if too low will overheat and shut off
Dec 31, 2015 | Pool & Spa
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Hurlcon pool pump reset switch where is it??
If there is a reset it will be locater near the power inputs, could be beneath a cover. Try looking here:http://www.hayward-pool.com/pdf/manuals/NorthStar.pdf
Nov 04, 2012 | Hayward 2HP Pool Pump Motor A O Smith...
My hurlcon mx series pool/spa heater stopped and displayed F2 fault. The operation manual action is" Allow water to cool,turn heater off then on again".Having tried this it did not fix it. Any...
Look at the pool water temperature readout. If this is a crazy figure say 60 to 120d deg C replace the thermistor line probe that senses water temp. its in the black water manifold.
Jan 23, 2011 | Pool & Spa
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Pool & Spa Logo
485 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
