Question about RTI 400 80008 00 Automatic Transmission Fluid Exchanger
Location on engine to where transmission fluid is to go on automatic range rover vogue 04 3.0d
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Typically, transmission fluid is added in a port on the transmission housing, not the engine. A service manual would have the specific instructions for your make/model/year. For a manual, check on the manufacturer's website and/or do a Google Search using the make, model, year and "PDF" in the keywords box.
Posted on Nov 08, 2014
Fuel leak range rover td6 vogue from middle to back of engine after being parked up .called rac they could find where it was coming from
sounds like fuel line or injectors ..remove covering to expose lines and injectors and clean area good then start car and look for leaks of gas......try not to drive it during this test if possible.
Nov 29, 2014 | Rover Cars & Trucks
Rover workshop manual
You would be better off buying the Haynes manual that covers all aspects of the vehicle. If you can afford a Range Rover Vogue, you can afford the $30 odd for a manual
Jun 26, 2014 | 2005 Land Rover Range Rover
The battery of the range rover vogue 2004 is died and I can't unlock the door
It does have a key slot think its behind the right side of the door handle and you pull the plastic cover off
Apr 14, 2013 | 2006 Land Rover Range Rover Sport
My Range Rover 4.6 Vogue could not reverse at all. Kindly Advice
sounds like reverse clutches in transmission also check trans fluid
Sep 08, 2011 | 2000 Land Rover Range Rover
My car is range rover diesel automatic 1998. when the engine is runing and the car is stationary you can see some time the speedometer moving up and down at that time the engine rev changes .is the engine...
the engine is fine- what you are seeing is the transmission fluid flowing fast enough in transmission to cause the speedometer to move- does the transmission slip at all? might be time to have transmission serviced- fluid and filter change.
Jul 30, 2011 | Land Rover Range Rover Cars & Trucks
How to replace air filter to a range rover vogue 2006 ..cant find it.
it's located in the big box behind the engine which is attached to the bulkhead. Take it off and you'll find the filter inside.
Feb 03, 2010 | 2006 Land Rover Range Rover
Stuck in 2nd gear when driving for a while
it sounds like your transmission is overheating. second gear is the default limp home gear the trans goes to when it senses a problem. pull the plastic allen head drain plug on the bottom of the transmission and be careful to let just a little of the trans fluid drain. the fluid usually doesn't drain unless the drain plug is all the way out. it usually wont let a little out at a time... if the trans fluid is burnt, brown, black, or not a nice clear red, you'll need to replace the transmission.
Jun 06, 2009 | 2005 Land Rover Range Rover
1991 Range Rover transmission problem
if you havent done it already replace the transmission fluid. it might help
Jun 02, 2009 | 1991 Land Rover Range Rover
Range Rover Vogue 1989 model 3.5l V8 fuel injected, with Automatic gearbox. I need the type of engine, gearbox, transfer box,and differential oil to be used on this vehicle. As well as the...
use 15w-40 for the engine, ATF for the gearbox and 80w-90 for the diffs and transfer box. engine and gearbox have dipsticks for the levels, the diffs and transfer box have removable plugs for level checking, fill until the fluid comes out the level plug.
Mar 09, 2009 | 1989 Land Rover Range Rover
RTI 400 80008 00 Automatic Transmission Fluid Exchanger Logo
61 people viewed this question
Top RTI Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a RTI Heating and Cooling Expert? Answer questions, earn points and help others
