Question about Cell Phones
<!-- from fixya rte -->How do I reset security password - Cell Phones
  • Cell Phones Master
  • 5,533 Answers
To reset a mobile phone security password if you have forgotten the original one! You have to wipe the data back to factory settings, this can be done by a phone specialist!
Posted on Nov 08, 2014
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
How to reset password for a samsung SDE-3004N DVR home security system. There is no remote for the system and have lost the password.
  1. Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
  2. Then enter the 4321.
  1. Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3 This reset will work on Android based DVRs only. All steps are performed on the device itself.
  1. Turn the device Off
    Wait 2 minutes
    • POWER,
    • HOME
    • VOLUME UP
  2. The unit should power on. Once it does, you can release power.
  3. Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
  4. Activate the reset using the HOME button.
Samsung Security DVR Reset Procedure #4 This reset will work on SDR models. It may also work on other models.
  1. With just the cameras showing, press the following in quick succession using the remote:
    • Freeze
    • Alarm
    • Freeze
    • Alarm
    • Freeze
    • Menu
    • Enter
  2. Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5 This reset will work on SDR models where procedure #4 failed. It may also work on other models.
  1. Press the DVR Button to place the system in DVR Mode
  2. Press:
    • Freeze
    • View
    • Return
Samsung Security Reset Procedure #6 Courtesy Sergio Ayala
  1. Reboot the DVR
  2. Once the DVR has rebooted, enter the following sequence on the remote:
  3. UP, RIGHT, 5, 3, 3
  4. You will be prompted to do a factory reset. Confirm
Sep 18, 2017 | Samsung Home Security
How do i reset password if i forgot the one that was entered
http://www.archerytalk.com/vb/showthread.php?t=2289354
talks of a reset button behind the battery tray.
and also from Moultrie themselves
Camera Password September 19, 2014
How do I set my camera password?
Step 1: From the "PROGRAM SECURITY" screen, press the OK button
Step 2: Use the Up/Down and Left/Right buttons to select a 5 digit security code of your choice
Step 3: Press the OK button to confirm the selection. Press the Right button to move to the next option.
NOTE: Please remember your security code. If the code is lost, you can contact Moultrie customer support to reset the password (charges may apply). Also, use caution when navigating through the Security Code option as not to set a code by mistake. For no Security Code, the setting should remain as "00000".
How do I reset my camera password?
A: If you forget your code, for your security, you'll need to contact Moultrie customer support to reset the password (charges may apply). For this reason choose a code you can easily remember, or otherwise be sure to keep your code in a safe, secure location, away from your camera. Also, use caution when navigating through the Security Code option at setup as not to set a code by mistake.
Camera Password
Jul 09, 2016 | Moultrie MFH-DGS-100 Digital Camera
Forgot Master Security password for Firefox 24.0.3 How do I recover to reset?
In the Firefox location bar, enter the following location:
chrome://pippki/content/resetpassword.xul
and press Enter key. The Reset Master Password page will appear. Click the Reset button, to reset your master password.
Remember: Resetting your master password will remove all of your saved usernames and passwords.
Sep 26, 2014 | Mozilla Firefox
Lost itunes password
If you know the answers to your security questions
  1. Go to My Apple ID (appleid.apple.com).
  2. Select "Reset your password."
  3. Enter your Apple ID, then select Next.
  4. Select "Answer security questions" as your authentication method. Select Next.
  5. Select the birth date associated with your Apple ID, then select Next to begin answering your security questions.
  6. After answering your security questions, you'll be asked to enter and confirm your new password. Select Reset Password when done.
If these steps didn't help you to reset your password, contact Apple Support.
If you have access to the email addresses associated with your Apple ID
  4. Select "Email authentication" as your authentication method. Select Next.
  5. Apple will send a password-reset email to the primary address or verified rescue address associated with your Apple ID.Didn't receive the email?
  6. Open the message and select the link to reset your password.
  7. When the My Apple ID page opens, enter and confirm your new password, then select Reset Password.
Apple support can be contacted here http://support.apple.com/kb/HT5699
Jul 08, 2014 | Apple iPhone Smartphone
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
Is there any possibilty to reset the password without knowing the previous password. my pc security password automatically resetted to default. can anyone tamper pc security software?
Hi there and welcome here,
Yes there is possibilities to reset the password, you can get a cd that can reset the Admin password and others accounts. That is the normal metod, you are lucky that it has reset and not make a new password :Oo, there are some that do that and after ask for money :OS.
Trend Micro should be a reliable Internet security and if you scan your machine once in a while there shold be no problem.
Additional info :
I have hear about that someone has made a password but after a time the password was reset by himself, here I do not know why, but I have done that to a computer and the next time I should help the person I did notice that the password was reset ted ??
Dec 17, 2009 | Trend Micro Internet Security Pro 2008...
Nokia 3110c mobile, i forgot security code.now how to reset security code?
there are two methods to reset the security code... firstly give me the IMEI number of you handset and i will give you the master code to reset the security password..its free
or the other one will be chargeable.. you will update your phone software all security password will reset and default password will set "12345" for nokia 3110c... its chargeable
i am also having the nokia 3110c... i was also having the same problem so i used the first method... free one
note my email id give me the IMEI code: sourav.gtb848@gmail.com
thankyou
remember to rate this sol.
best regards,
Sourav
Nov 03, 2009 | Nokia 3110 Cellular Phone
Can't turn off Vista Master Password for the software security device
Removing your master password
  • Firefox 1.5: "Tools -> Options -> Privacy -> Passwords -> Remove Master Password"
  • Firefox 2.0: "Tools -> Options -> Security -> Passwords -> Uncheck "Use a master password". You will be prompted for your Master Password.
  • Thunderbird: "Tools -> Options -> Privacy -> Passwords -> Remove Master Password"
If you have lost or forgotten your Master Password or you want to disable the feature, you can reset your master password. Upon resetting, you will lose all the stored information in the Password Manager as this is a built-in security feature to prevent people from simply resetting your Master Password to gaining access to your passwords.
For Firefox you can also look at the Troubleshooting section in Password Manager.
  • Firefox: Enter "chrome://pippki/content/resetpassword.xul" in the Location Bar, press Enter, then click "Reset"
  • Thunderbird 1.5: "Tools -> Options -> Advanced -> Saved Passwords -> Master Password -> Reset Password".
  • Thunderbird 2: Choose Tools – Error Console, paste the expression: openDialog("chrome://pippki/content/resetpassword.xul") and press the Evaluate button. That will open a dialog asking you if you want to reset your password.
  • For Mozilla Suite: "Edit -> Preferences -> Privacy & Security -> Master Passwords -> Reset Password".
Taken From MozillaZine, http://kb.mozillazine.org/Master_password
SM
Apr 04, 2008 | Microsoft Windows Vista Ultimate Edition
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
