Question about Humminbird 1198c GPS Receiver
It's saying that my 360degrees transducer is unconnected do u have to use another transducer or do u have to do it on screen
Why do I get a clearer picture on my screen when I set my transducer on single 200mhz beam,and the picture is not clear and I get a poor bottom view when set on single 83khz or dual beam 200/83 kHz.
It it understandable that different resolution would give you a better picture bit, loosing reception??? Judging from what you have tried I suspect the cable is damaged some place. If you have extra cable... try not to have the excess cable rolled up in a tight roll. This may cause interference. Make sure the transducer is aimed as flat as possible.
Feb 04, 2015 | Boating
I have want to know what it means what tool to use
it is a special tool marked into 360degrees set it to zero then tighten another 220 degrees . Most head bolts are torqued down first then a further ??? degrees.
Sep 28, 2014 | Cars & Trucks
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
Gps wont work but fishfinder works fine
This model has two versions, one with the GPS as an external piece, and one with the GPS mounted internally. If the location of the internal mounted GPS cannot get a clear shot at the satellites overhead, it will tell you it cannot get a GPS fix. If it says it is disconnected, you may have a problem with the internal GPS. There are external GPS pucks available for this unit. Here is a helpful website.
http://www.humminbird.com/leading_innovation/fishing-systems.aspx
Nov 07, 2011 | Humminbird 788ci Color Fishfinder Combo...
My Garmin depth finder/gps combo is giving me a false depth reading,like way way outta sack,not a foot or two. It came as an extra on a boat I purchased and elsewise seems ok,just inaccurate depth. Is it...
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
HOPE THIS HELPS!
Sep 03, 2011 | Garmin GPS
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Sep 04, 2017 | Humminbird Fishfinder 550
My fishfinder lowrance x85 the screen is fading is there any way to tell if it is the unit or the transducer and is there another uniy yhat I can use with that transducer so I won;t have to rewire it...
It is not the transducer. the transducer just provides the sonar reading back to the display. The issue is with the display head unit. Have you tried to adjust the contrast for the fading? Does the screen disappear after awhile? Is the head unit mounted close to other navigation equipment, such as a Compass that may cause interference?
Jul 24, 2010 | GPS
Transducer not connected
my 947 c says transducer not connected
Jun 14, 2008 | Humminbird 947C GPS Receiver
Humminbird 1198c GPS Receiver Logo
57 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
