Question about Car Audio & Video
I have a 1993 ford laser....I'm tryin to change stereo..... but the wires are completely different as to the compenent wires???
The component wires are red yellow black blue/light blue green green/black white white/black grey grey/black purple purple/black the car harness is blue/black blue/red red/black orange white purple blue/yellow please help???
  • paul anderson
    paul anderson Nov 08, 2014
    which wire goes to which please
  • Car Audio & ... Master
  • 5,499 Answers
You will need a new wiring harness adaptor either from Ford or the stereo manufacturer!
Posted on Nov 08, 2014
Testimonial: "that I do have.....but all the original wires don't match the colour wires that came with it"
  • 2 more comments
  •  Mikey
    Mikey Nov 08, 2014
    Then you should be able to get an adapter that fits between the standard ford plug and your new stereo plug and that will be from either the Ford dealer or the stereo manufacturer!
  •  Mikey
    Mikey Nov 08, 2014
    If you don't want to do that then get the wiring diagram from ford for your original stereo wiring! You have the wiring diagram for the new stereo, so cut the wires and reconnect without the plugs!
  • paul anderson
    the question i'm asking tho....... which wires connect to which....the compponent wires are red, yellow black, blue/light blue.....the car harness wires are red/black, orange white, purple???
  •  Mikey
    Mikey Nov 08, 2014
    Stereo manufacturers don't generally keep wiring colours universal other than live and earth! The only way you can be sure is to follow a wiring diagram from the stock stereo and the replacement one! Just naming the colours of wires will not help!
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
SOURCE: need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
Posted on Jul 29, 2008
  • 136 Answers
SOURCE: Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Posted on Sep 04, 2009
Testimonial: "Thanks that was GREAT!!!!"
SOURCE: I am looking for the wiring 97 fiesta stereo
Ford Auto WIring Diagrams, Image results for 97 Ford Fiesta Wiring Diagrams
Posted on Jan 23, 2010
Stereo wire codes diagram for a 1993 Ford Aerostar
Its easier if you get the $6 harness piece and attach it to the stereo harness and plug it in. Than to splice the wires on there. But here is the wiring color codes http://www.the12volt.com/installbay/stereodetail/795.html
Jan 26, 2015 | 1993 Ford Aerostar Extended
Dash lights /on 1993 ford taurus
remove steering column plastic set seat all the way back remove linkage indicator line(little wire cord to stering column on a hook) under dash remove the molding from stereo to driver door remove dash cluster look for cluster lights replace...reverse process...
Apr 07, 2013 | 1993 Ford Taurus
Different cords
You will need to go to locate auto parts store and buy the adapter which will allow you to fit the stereo without any wiring modifications.
Jul 29, 2010 | Pioneer DEH3200UB w USB Input iPod...
The wires in my 1993 ford taurus have different color wires than my new radio
I would get a wiring harness adapter for your car. You can wire your stereo to the harness and then plug it into the car's exsisting plug.
May 21, 2010 | Car Audio & Video
Need stereo wiring Diagram for 1993 Ford Tempo Gl
I just installed an aftermarket stereo in my daughters 93 Ford Tempo.
I have seen others post on-line and they were incorrect for my 93, the one I found my have been for a different year. THere are 2 wiring harnesses on the stock/OEM unit, one for the speakers (#1) the other for the power (#2). Here is what I found:
Harness #2
Constant 12 v+ : Green/Yellow
Switched 12v+: Yellow Black
Ground: Black/Yellow
Illumination: Blue/Red
Unused: Orange/Black
Harness #1
Left Front (+): Orange/Green
Left Front(-): Blue/White
Right Front(+): White/Green
Right Front(-): Green/Orange
Left Rear(+): Pink/Green
Left Rear(-): Tan(Brown)/Yellow
Right Rear(+): Pink/Blue
Right Rear(-): Brown/Pink
Hope this helps.
Dec 27, 2009 | 1993 Ford Tempo
Fitting a stereo in a 1993 Nissan Sentra
if you are putting an after marker stereo the wiring is different from a stock radio some audio stores sell adapters for after market stereos that you jus clip on to stock wiring
Nov 14, 2009 | 1993 Nissan Sentra 4 Door
How to install into my 1993 ford probe?
Here are the factory wiring colors match these to the aftermarket names (12v to 12v Ign - Ign, etc)
1993 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Light Green/Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
May 26, 2009 | Car Audio & Video
They are completely different harness connectors !
No problem. All you need is your vehicle year and make and you have that. Go to Wal*mart or Target and get a wire harness adapter. Cost about 10-15 bucks. It's in the auto/stereo department. If you'd like to pay a little more then go to BestBuy. This adapter will allow your vehicle harness to plug into it and tell you where to connect the wires onto the wires of your Sony stereo. Very easy. Have a great day.
Apr 19, 2009 | Sony Car Audio & Video
I own a 1993 Ford Explorer and my radio just stopped working. I checked all my fuses and they are all fine. What could be the problem
the radio may be defective, pull it out and verify power to the radio, u can buy the radio removal tools at any NAPA parts store or get them from Ford, they are very cheap to buy. here is the wiring colors and what they do, u will also need a cheap 12 volt test light, about $6
1993 Ford Explorer Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
Jan 08, 2009 | 1993 Ford Explorer Limited
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
