Where is the menu button on the b5 remote - Computers & Internet
The printer says Load MP feeder B5. how can I fix this.
Several options here:
1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
Link to the user manuals for this machine : click here
Oct 19, 2010 | Lexmark T632 Laser Printer
Eurovox codes for the 05/10/09
5a 01
updated 05/10/09
c2 b5 be 41 0d 9b c5 7c
8e 80 d7 ef 44 93 02 2b
(okey dokey (~:)
Oct 05, 2009 | Sony Televison & Video
Need codes for Eurovox 5A01
aa b7 d1 d9 ce 8e 83 af
These codes are working fine for 5A 01 on Tuesday 8th september 2009
Sep 06, 2009 | Televison & Video
Codes for eurovox max telewest/virgin bradord area
press menu then press the yellow button on your remote
then type in
98 bo ba 52 d3 21 08 b4
d2 ea 29 b7 b5 52 e9 ad
Nov 30, 2008 | Televison & Video
Codes and how to set box
1stly.......press.............menu............then.............yellow button on ur remote..........it should pop up?? unless you got old box its bluebutton........then use ur remote to enter codes such as(letter A would be TV)it tells you at bottom of screen if your following these steps..........then 1st two boxes at top...............enter...............5A 01 if ur telewest.........then codes
key 00 = 98 B0 BA 52 D3 21 08 B4
KEY 01= D2 EA 29 B7 B5 52 E9 AD
then press................OK...............and then..............EXIT that should be you sorted always use remote to enter codes........recall..........info.............p+.............p-.....them buttons u should see at bottom screen??
hope helps?/
charlize
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox max v virgin media bristol codes
PRESS THE MENU BUTTON FOLLOWED BY YELLOW BUTTON AND UL SEE BOXES USE UR REMOTE TO PUT CODES IN IT TELLS YOU AT BOTTOM SCREEN WHICH BUTTONS TO USE FOR WHICH LETTER CODES ARE.................
5A 01
HOPE THAT HEL[PS
How to input codes in the Eruovox maxv
OK.........PRESS THE MENU KEY..........THEN THE YELLOW KEY ON YOUR REMOTE.YOU WILL SEE BOXES USE UR REMOTE TO PUT THE CODES IN SUCH AS(RADIO........P+ INFO ETC)THESE SHOULD SHOW UP AT BOTTOM SCREEN TELLING YOU WHICH ONES TO USE ON REMOTE??? THEN ON TOPLINE THERES 4BOXES??? ENTER............5A 01.....THERES 2LINES BELOW THE CODES ARE BELOW FOR YOU
USE THE REMOTE TO ENTER CODES DO YOU NO WHAT I MEAN???
LIKE FOR LETTER "a" ITS THE BUTTON.........TV............ON REMOTE
THE LETTERS ARE PUT IN WITH UR REMOTE IF U LOOK AT UR SCREEN AT BOTTOM IT HELPS YOU TO NO WHICH BUTTONS TO USE
HOPE THAT HELPS IF NOT EMAIL ME
I need a code for eurovox. Can anyone help?
WEDNESBURY, WESTMIDLANDS.
virgin media.
EUROVOX
codes.
press menu on your remote and then press yellow button.
follow correspondant letters and numbers and type the letters and numbers as shown below.
5a 01
04 4d 6f 7d d5 c9 f7 9b
when codes are in, press ok to save and then press exit.
goodluck
kind regards.
kathi
Nov 29, 2008 | Televison & Video
Codes for eurovox for virgin media please help me thanks
hi go to wizardmod co.uk .
download the keys tool bar and the keys worked for me.
u must register on this site other wise u cant download.
Eurovox not working
TELEWEST (west mids)(b'ham) 28/11/08
00 04 4d 6f 7d d5 c9 f7 98
01 d2 ea 29 b7 b5 52 e9 ad
CODES WEDNESBURY. WESTMIDLANDS..
VIRGIN MEDIA.
press menu and then the yellow button.
5a 01
d2 ea 29 b7 b5 52 s9 ad
after putting in code, press ok to save then press exit..
WORKING FINE..
kind regards everyone and thankyou..
GOODLUCK.
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
