Question about Boating
I have a suzuki outboard motor dt30-91,i didn't used it for about 2 years,now it lost spark,can't found the problem.please help.
    Genius:
  • 2,494 Answers
?heck the C.D.I ign coil .also switches and wiring plugs for corrosion.
Posted on Nov 08, 2014
  • 5546 Answers
SOURCE: Need to know year of this outboard
Go to the Search, type in suzuki dt60, there will be many items to help. Its between a 1977 and 1984. Some of your numbers are serial #s and you can probably use the #6001 or the second number to be more exact.
Posted on May 04, 2009
  • 23 Answers
SOURCE: What is the fuel/oil ratio I should use with my
What kind ? Evinrude,mercury,ect
most 50 to1
Posted on Jun 19, 2009
SOURCE: need to know year of outboard motor
1992
Posted on Jul 02, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
  • 677 Answers
SOURCE: How much gear oil in a 1985 2 hp suzuki outboard motor?
The bottle that the g/box oil comes in should hve a tapered nozzle.You fill the g/box through the bottom drain hole untill it overflows out the top hole.With both screw plugs removed,squeeze the oil into the lower hole untill it flows out the top hole then reinsert the lower plug first.They dont take a lot of oil but this removes all the air bubbles in the g/box.Hope this helps
Posted on Dec 12, 2009
My question is about a suzuki outboard motor not a washing machine
PDF]Suzuki Outboards Workshop Manual - Manuals ...
www.motoren.ath.cx/outboard/suzuki-outboards-workshop-manual-1.pdf
This manual covers the topics that a factory service manual (designed for ..... include rudders, brackets, outboard motors, outdrives, diving platforms, or.
Oct 07, 2015 | Boating
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
Suzuki outboard
It sounds like it is starving for fuel. Do you store it out of the water over the winter? Or do you use it all year round? If it gets stored, you probably need to get the entire fuel system cleaned out. If you use it year round; when was the last time it received a full service? It could be worn out parts. Age is the enemy here; motors do different things over time depending on how they're used.
Apr 20, 2014 | Boating
Suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Are the multi grade 2 stroke oil mixes safe? I have an old Huskvarna 360 that ran for about 14 years and started havening start up problems when warm after I started using a multi grade mix. I just...
Many of those are outboard motor 2-cycle oil and do not perform well in the elevated temperatures found in chainsaws, I will not use them. I use Stihl 2-cycle oil in my Husky. How old is the mix? 1.5 months or less recommended by all saw manufacturers because of the ethanol in todays fuels. Try cleaning the muffler and spark arrestor.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Husqvarna Garden
L was driving my boat and the out board motor stopped l tried to start it but it smelt like it was flooded .l pulled the spark pulgs out cleaned them and tried to start the motro without the spark plugs to...
If i had year make and model I could give you detailed instruction. You can do a few simple test to make the troubleshooting easier. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the year make and model I'm giving you a average numbers. Look at your Clymer manual for exact numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for only 30 days in 90 + degree heat. It turns to a gummy residue called varnish. It clogs up carberators and fuel injection system. I don't know year make and model so i dont know what fuel system you have. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine cover clean it. mercury fuel injected outboards has a canister fuel filter under engine cover. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing on fuel delivery system. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 04, 2009 | Boating
Apr 30, 2009 | Boating
Boating Logo
75 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
