What relay do you use eb falcon air cond
What sort of relay for a eb 5litre air conditioners
    Genius:
  • 2,494 Answers
It down under surge tank near the battery just take the old one with you when you go for the new one.
Posted on Nov 08, 2014
3 Suggested Answers
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
  • 45 Answers
SOURCE: My air conditioner doen't start. I have a goodman air cond.
Check to make sure that the power is on to the outdoor unit and the furnce. Check breakers and fuses. There may also be a disconnect outside located by the condenser. It is probably a gray box, loft the cover and make sure the shitch is on. Otherwise if you turn the thermostat to cool, if the furnace blower comes on and the outdoor unit does not check the following. Turn off poer to outdoor condenser and open up the electrical compartment on the condensing unit outside. There is a round or oval cylinder inside. Its probably silver in color. That is the capacitor. If the top is bulged, its a true sign of a capacitor failure. Take the capacitor out and take it to your local HVAC Wholesaler of contractor. The part should cost you around 15 to 25 dollars. If this does not work, let me know.
Posted on Jun 05, 2010
Sorry it's a au falcon 5litre
What is wrong with an AU Falcon is it the V8?
I have a 6cyl AU with just under 200,000km and it has not giver any problems
Apr 09, 2017 | Cars & Trucks
I need a diagram for installation of timing chain for an eb ford falcon 5litre
dont do it yourself but if you want to then check youtube vids or search on google you should get it
Oct 01, 2013 | Cars & Trucks
Tech 2000 just quit. The problem is the outside unit. I cannot get it to start when I manually push the contactor. No fan and no compressor. Unit just hums for a couple of seconds and then no hum. ...
Sounds like a shorted capacitor. THe capacitor is located right beside the contactor. Looks sort of like a batter. Probably has 3 posts on top. If its shorted it usually will look pregnant or swollen. A capacitor is not very expensive. You can get one at any air cond supply house.
Jul 13, 2011 | Carrier 38CKC042 Air Conditioner
High pressure air cond line has frost about 10 feet inside home
You have a low freon charge or a blockage in air flow. Check the filter if it is clean then there is a low freon charge in your system in which an a/c tech will be needed.
Good luck on repairs
Dave
Jan 06, 2010 | Amana PTH123B35AJ Air Conditioner
What does the error code VC/VH trip mean on a Bryant out door hp cond.
vC/vh Trip or code 6. The start cap and or the start relay is bleeding voltage to the comp in the off cycle. Replace both the cap and relay for the fix.
Jul 09, 2009 | Bryant Heating & Cooling
Wimdow Air Cond.
Sorry, that's a no. There are, however, window air conditioners made for casement style windows which are tall and narrow. I know GE used to have them. Check geappliances.com. There are also " portable " air conditioners which sit on your floor and vent through hoses to a window.
Jun 18, 2009 | Heating & Cooling
Eb series electric heat/air cond./repair
I need more information to help you. When you say it "turns on" what does that mean? Only the fan works? If so does the compresser run? If not, the start relay could be the problem.
Ray
Sep 14, 2008 | Dayton Electric Heater
Air handler
This should be doable: First get pen and paper-start at the furnace, theres a group of 5-8 wires leaving the furnace anfd going to the thermostat and a group of 2-3 going to the condenser outside that all need to be identified and the location in the furnace recorded if your furnace has a control board simply right the letter and the corresponding wire color:and whether it belongs to the condenser grp or the T-stat grp.
Furnace
R-red-to t-stat
C-yellow to cond
Y-red to cond and yellow to t-stat
G- green-to t-stat
W- white- to t-stat
If you dont have a circuit board youll be doing the same thing but using the components rather than letters;
Transformer 24v- red to t-stat
transformer 24v com -yellow to cond
Red from cond connected to yellow from t-stat
fan relay - green to t-stat
gas valve - white to t-stat
K then go to you t-stat and simply connect the corasponding component or leter to the thermostat gterminal
Cond Furnace Thermostat
yellow com- blue -C or B
gas valve or w-white -W
fan relay or g -green -G
trans 24v or R -red - R
red connection to cond or Y on board -Y
Hope this helps.
Jun 12, 2008 | Quasar HQ2052UH Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
