Question about Humidifiers
What type of filter does the p/n 30lbm832xb1 cool humidifier require?
I want to know best way to clean the humidifier and how often?
It all depends on a couple of factors.
First is the type of humidifier your using. Portable or whole house connected to the furnace. Steam, ultrasonic or filter. Your unit's instructions is the best guide as to how often you need to clean it and this can vary from every day to once a heating season.
My recommendation is to watch and clean the unit as soon as you see scale forming. Then in the future, reduce this to just before you see scale forming.
The second is the type of water you are using. Hard tap water is the worst and usually will require every day for small portable steam or ultrasonic units to once a week for filter models. For central whole house humidifiers, once a month (perhaps as little as every two weeks if your water is really hard, >10 grains hardness). There is no fixed formula for this, the idea is to perform on-going, preventive maintenance.
Soft or conditioned water will contain the same amount of minerals as hard, but the softener has replaced the calcium minerals with sodium minerals. (Sodium bicarbonate actually).The result is the humidifier will still form scale but it much easier to remove. With soft water scale, you can just break up the scale with your fingers and the filters can just be submerged in clean water and the salt scale will re-dissolve.
Third, with distilled water, you may only need to clean any of these units annually. (No minerals to for scale).
With any filter humidifier, consider using a commercial bactericide to prevent the growth of bacteria when the water sits for long periods (>14 days). Not so critical with soft water as the salt will retard the growth of bacteria, but very important with hard or distilled water. Don't use this product in ultrasonic or steam humidifiers as it will be carried into the air along with the water vapor, and can be considered as toxic.
With hard water, use a 50/50 solution of white vinegar and water to dissolve the scale buildup. This works best if done on a regular basis. If left go too long, it become impossible to clean properly. You need only use regular water when using soft or distilled water in your humidifier.
Dec 25, 2015 | Kenmore Cool-Mist Ultrasonic Humidifier...
I only used my machine for just about two weeks (only in the evenings)with a brand new filter and already the top of the filter has turned yellow/brown and brittle. Is it normal to go through a filter so...
how long the filter will last depends on your water .. if your water has a high mineral content then that is left behind as the water evaporates from the filter/wick ... the yellow brown sounds like calcium deposits .. calcium is often added to water to give it a good taste .. that may be beneficial for you but will build up on the filter .. it doesn't hurt much until it starts to clog the voids in the filter material .. as long as air gets thru then the deposits will be ok .. normally the filter should last about 3 months .. if you use distilled water (with no calcium added) then much longer .. if you have hard water then less .. there is a tablet that you can add to the water to reduce the calcium buildup .. the manufacturer of your humidifier will likely recommend that .. thats often available from hardware stores also ..
so your choices are:
1. don't worry about it until the filter becomes clogged
2. use the anti calcium tablet or something like ProTec PC-1 Humidifier Tank Cleaning Cartridge
3. use distilled water for really long filter life
4. plan on replacing the filter every 3 months
other types of humidifiers have other problems .. the hot water type gets calcium deposits on the heating element requiring cleaning a couple times a year, usually with vinegar or a calcium solvent .. that takes awhile..
the Ultrasonic type doesn't generally have problems with internal deposits because it blows moist air out including the calcium .. that produces a fine dust on surfaces in your house ..
of those types the filter system like yours is easier to maintain than the hot water type and doesn't leave dust behind like the ultrasonic all work better and longer if the water is pure .. distilled water doesn't cost much but you have to be careful .. read the small print .. some of it will say "calcium added" .. you don't want that .. if you use only distilled water then the filter should last the whole year ..
Sep 26, 2010 | Vicks Cool Mist V3500 Humidifier
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
Replacement filter question
Filter part number is BCM100. Filters are sold at Sears. Also available online. Part number is listed on bottom of humidifier.
Dec 04, 2008 | Bionaire BCM7204-U 3 Gallon Humidifier
Hm495tg
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
Filter
Yes but operation without filter is not recommented.
Jan 19, 2008 | Honeywell Cool Moisture HCM-560 Humidifier...
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
Humidifiers Logo
88 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
