Question about Kitchen Appliances - Others
FoodSaver Vac 200 is plugged in but won't turn on
The problem is not no power to the outlet....Help
  • NotSoCoolPix Nov 08, 2014
    Hi T Preston, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    For instance: when was the last time you used it?
4 Suggested Answers
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
  • 4090 Answers
SOURCE: garmin nivi 200 won,t turn on
well if the plug is not making contact it cant recharge. you need to have it repaired and that may well be costly as it will require a new motherboard. Parts are no longer soldered or repaired The motherboard will be repalaced and the basic board is ^$90 the labour 1.5 hrs o 2 hrs minimum at $95 I am sure you will be able to buy a new model for the same cost
Posted on Aug 01, 2009
  • 192 Answers
SOURCE: Need a part number for a 3310Le 110 vac power supply
Oops!
Generally the unit should have a part number attached to or printed on it somewhere. This is for the board with the power switch attached, it's called the power supply unit, so hopefully this is what you are looking for.
There seems to be two possible options, so you will need to determine which is the correct unit you need.
AZ23 0204 - Power Supply Unit: 100V (RoHs)
H555 5010 - Power Supply Unit - 120V
Posted on Nov 13, 2009
Kenmore Washer won't power on 796.4002
Could be one of the following problems;
  • Power cord is not properly plugged in. (Make sure that the plug is plugged securely into a grounded, 3-prong, 120-VAC, 60-Hz. outlet.)
  • House fuse is blown, circuit breaker has tripped, or power outage has occured. (Reset circuit breaker or replace fuse. Do not increase fuse capacity. If the problem is a circuit overload, have it corrected by a qualified electrician.)
Source: Kenmore 79640021900 Manual
Aug 25, 2015 | Kenmore Washing Machines
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Trying to find a gasket for ......food saver vac 820
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
Aug 14, 2011 | Tilia FoodSaver VAC420
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Dec 30, 2008 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
123 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
