Question about Konica Minolta 7033 Drum Only
Konica 7033 error F 51-4
How to trouble shoot this error F 51-4
    Sergeant:
  • 269 Answers
4 Suggested Answers
  • 990 Answers
SOURCE: We have a Konica 7033 and has the message Front
Hello sir; Check the door switch actuator is broken ? or out of possition need to adjust it.
Posted on Oct 09, 2009
  • 1294 Answers
SOURCE: konica 7033 copier showing fault F52-1
Clean or chnage the main body fun cooling motor.
Posted on Aug 18, 2010
fivemayur
  • 414 Answers
SOURCE: konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Posted on Nov 09, 2012
How do i fix may konica 7033 displaying f52-1 error
F52-1 Cooling fan problem
or
F52 Main motor drive problem
Mar 27, 2015 | Konica Minolta Copier Toner 7033/7040...
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 35-1
Access the 25 mode (power the machine ON while holding down the 2 and 5 keys).
2. Select [1: Software switch setting].
3. Select software dipswitch #3 using the left up/down arrow.
4. Select bit number one.
5. Set the switch to 0 (OFF).
6. Press PREVIOUS SCREEN to end setting.
7. Power OFF/ON to exit the 25 mode.
Jun 09, 2014 | Konica Minolta Copier Toner 7033/7040...
ERROR CODE F-46-8 IN MY COPIER
I think you need to replace the front door interlock switch ( very common part ), and then take some time and adjust the bracket for a really good positve closure on the switch....leave the display panel off during this adjustment so you can get a good look at the switch closure. There is no factory adjustment on the bracket- you might have to bend part of the bracket to get a good closure. Open and close the front door a couple of times just to be sure and there you go. This front door interlock switch is a common failure on the 7033, 7040, and 7045's and will give you all kinds of crazy symptoms.
May 11, 2014 | Konica Minolta Copier Toner 7033/7040...
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
Konica 7040 trouble code 51-4
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
I have a Konica 7033 copier with error code F-35-2
Access the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
2. Press [1: Software SW].
3. Select software dipswitch 3-1 using the arrow keys.
4. Set the switch to OFF (0).
5. Press [Return] to end the setting.
6. Power the machine OFF/ON to exit the 25 mode.
good luck
May 04, 2009 | Office Equipment & Supplies
Konica 7033 error code F-51-4
my machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Sep 18, 2008 | Office Equipment & Supplies
Hp 4p printer related problem
Error 51 (beam detect error) Trouble shooting suggestions: Check seating on laser/scanner assembly Replace scanner assembly
Aug 30, 2007 | HP LaserJet 4p Printer
Konica Minolta 7033 Drum Only Logo
147 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
