Question about Microwave Ovens
I bought an ossculating fan made by Living Solutions at Walgreens and there is a very small fuse in cord, it burned out and I can,t find a replacement fuse anywhere, believe me I tried fan stores, dept stores, all walmarts targets,store where I bought, hardware stores etc, Just don,t have, where can I find this darn fuse, size is 25 amp-125v, found one that's 3amp did not work Help anyone, no website for manufacturer either
Your 25 amp fuse should not have burned out. House circuits are 15 amp and 25 amp. My only suggestion is to contact the manufacturer
Posted on Nov 08, 2014
  • Kandie kader
    Kandie kader Nov 08, 2014
    Sorry it's a 2.5 amp fuse in the cord 125 v
Its a 2.5 amp not 25 amp fuse
Posted on May 29, 2016
    Loyalty:
    Visited the website for 30 consecutive days.
  • 521 Answers
You should check Radio shack. If not you need to look for electrical supply company that does office and computer parts. You should be able to type in 25-amp-125v fuse then go to shopping and check images if using google. Hope this helps. Mike
Brada microwave
please make this test and fix it. God bless you
  1. Inspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switch If your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fuses To determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motor Locate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Dec 16, 2013 | Sanyo Microwave Ovens
It wont turn on
Dec 10, 2013 | Sunbeam Microwave Ovens
I bought a mircowave and i plugged it in and it wont turn on
make this steps and fix it. God bless you
Panasonic microwave will not power on
follow this steps and fix it. God bless you
Nov 27, 2013 | Panasonic Microwave Ovens
Why does light come on, no motor or cook. Display is good
please follow this steps and fix it. God bless you
Nov 27, 2013 | Microwave Ovens
JES1290SK No motor or inside light when turned on. Display works. Light works until turning on unit.
please see the steps and fix it. God bless you
Nov 27, 2013 | GE JES1290SK 1.2 Cu. Ft. Countertop...
MICROWAVE FUSE BREAKDOWN
follow this test and fix it. God bless you
Nov 26, 2013 | Microwave Ovens
Not turn off
Nov 23, 2013 | Whirlpool MH3184XP Microwave Oven
Rmc305pdq2 door error
please use this stpeps and fix it. God bless you
  1. nspect the power cord Unplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
Nov 22, 2013 | Whirlpool Microwave Ovens
Where is the fuse for this microwave? The
Generic Comment:
First check the breaker - then check that you are not on a GFI protected line.
Remove the cover. Somehwere probably on the right hand side near where the power cord comes in should be a fuse.
This should answer your question. I dont think this is your problem, however. The fuse Im talking about protects the entire device. You have a burned out light and a fan that doesn't work.
With the cover off, it should be easy to find the light and inspect, check and replace it if necessary. You can inspect the fan at the same time and maybe discover why it isnt running if that is indeed the case.
I hope this helps you
a
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
116 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
