Aircon won't turn on
Model no AOT24RNBL
    Master:
  • 602 Answers
Check the capacitor The top where the wires clip on should be flat. A power surge. (Usually caused by lightening strike) will cause the top to swell a little.
Posted on Nov 10, 2014
Why the rpm of toyota corolla 1994 model goes down when aircon is turned on
Because aircon uses a lot of power, it causes the revs to drop and the car to use more fuel. Just a fact of life. If you don't NEED to use the aircon - don't use it. And if you do need to use it, expect expenses to rise.
Dec 07, 2013 | 1994 Toyota Corolla
2010 Vauxhall Astra H (1.4 sxi) Air con previously not working. Had car re-gassed, still no joy. In Opcom Aircon was set to not activated. Changed this to "with clutch setting" an Aircon working now:-) ...
air cont flow sensor may have failed cannot remember on 1.4 model but on 2.0 model its on the left side of the engine. it could be this. a/c dont usually have codes to store. accelerator code is the sensor on the intake on the side. prob just needs cleaning mark were it fits with a pen and take off. on op side there is a hole spray some wd40 in the hole cover it and shack it around . then tip out and leave to dry. then put back on. should be fine then.
Aug 04, 2013 | Vauxhall Cars & Trucks
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Unit will heat only will not cool and how to repair
we have a split type gree aircon, with one (1) horsepower. it was just newly installed, around 6 months ago. we are just surprised that one when my wife turned it on, thru the use of its remote control, the indicator box on the aircon reads or flashes "F2". I detached the batteries of the remote control for severa hours and I also detached the power cord from the wall socket, but it was to no avail. it did not work. with "F2" on the indicator box, the aircon won't give cool air, it is just working like an ordinary fan. please help us.
May 17, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
1999 vw beetle, a/c suddenly stopped working, fan blows and light comes on, but compressor doesn't
Have the aircon gas checked. If there is a leak in the system the pressure will be to low and the compressor won,t kick in. Re-gas aircon and check for leaks.
Jun 08, 2010 | 2000 Volkswagen Beetle
Vw sharan tdi cl 96/97 model,does this model have aircon
sharan aircon front fan not working. Fuses 15 , 20, &21 working ok. please help
Jul 05, 2009 | Heating & Cooling
I have a honda civic esi 93 model,when i turn on my aircon the idle drop down,there is no problem with the idle when the aircon is not running,do i need to replace/check something to my aircon system?
As long as the engine doesn't die that is pretty normal for those cars. earlier a/c systems had much heavier compressors and took an extremely large amount of energy to turn. that is what causes the idle to drop. If you do experience anything other than that then i would have it looked at. If it makes the engine pull way down then you could be having compressor issues. hope i helped and good luck.
May 07, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
