Question about GM Buick lacrosse seal kit. front axle. front wheel drive axle shaft
How do i replace the fluid once i replace the front seal on the drive shaft ( 4 wheel drive )
I see no place to add fluid once i change the front seal on the drive shaft
    Genius:
  • 2,494 Answers
Check where the speedo drive goes into the gearbox it could be the filler hole.
Posted on Nov 08, 2014
How do you replace rear oil seal in 1994 Isuzu Standard tranmission
Chockblock front wheels to prevent truck rolling, and jack vehicle up and place a jackstand under frame to prevent vehicle falling. Remove driveshaft, seal is now visible to be pried out for new one to be lightly tapped into place with a rubber mallet or hammer, along with a wooden block, taking care to keep new seal straight while replacing. replace driveshaft and check fluid level, lower vehicle and remove chockblocks.
Feb 13, 2015 | 1994 Isuzu Pickup
How to replace front differential seal on 2007 4.7 toyota tundra
This is not easy....You will need air tools ,spray penetrate,seal remover,hammer,and Jack stands..Seal installation tool,.All proper tools..safety glasses.correct seal replacement.,new lock nut...Set park brake,block rear wheels,raise vehicle front and safely place jack stands under each side of lower control arms..Spray lube front drive shaft mounting hardware and lock nut that holds Yoke on front diff..Let it set to penetrate..put vehicle in neutral..Mark shaft to yoke location and direction perfectly because it has to be installed in perfect timing exactly how it was removed..,Remove drive shaft..Remove lock nut and yoke from front diff...You will have to hold yoke while removing lock nut because it will spin..PROTECT HANDS..( These can be VERY DIFFICULT to remove..Sometimes they have to be heated..You will need a yoke removal tool if it doesn't tap off with hammer...Mark exactly the yoke to spline location before removal..You can take close up photos however Mark it also to be sure...If you re-install it wrong it will vibrate terribly..Once yoke is removed You can remove seal.Make sure the new seal is correct...CAREFULLY..DO NOT DAMAGE SPLINES WHILE REMOVING..Sometimes even the perfect seal remover will damage splines..So cover it to protect spline threads..Clean all areas once seal is removed..Make sure nothing is pitted or damaged...Install new seal with installation tool..Lightly,perfectly tap it flush with diff..You can use old seal to install new seal if you don't have installation tool But only a pro should do that...Once in place Line drive shaft yoke with your marks and tap it on ..Use NEW LOCKNUT AND TORQUE IT TO SPEC..Install drive shaft as marked..torque to spec..Lower truck and check fluid..Complete..
Dec 13, 2014 | Toyota Cars & Trucks
2002 mercury mountaineer suv 2002 noise clicking when backing up
if this is a 4wd drive model , try having someone listen to front wheel hubs when you back up , id be conserned that the front wheel hubs seals have gone bad and there is now dirt inside bearings and has damaged them , also ive seen clicking caused by locking hubs not fully disengauged by dirt stuck inside
Aug 30, 2014 | 2002 Mercury Mountaineer
Intructions on how to replace a gearbox on a 1987 GMC suburban
set the front wheels in straight ahead position by driving vechicle a short distance on a flat surface. raise and support the vechicle safely on jack stands.place a drain pan below the steering gear. disconnect negative battery cable.disconnect fluid lines.cap the openings.mark the relationship of the pitman arm to the pitman shaft.remove pitman shaft nut and then remove the pitman arm from the pitman shaft using puller J - 6632. remove the steering gear to frame bolts and remove the gear assembly. TO INSTALL align the flat of the flexible coupling with the flat on the shaft push the coupling onto the shaft until the wormshaft bottoms against the end of the shaft.install the pinch bolt. make sure the bolt passes through the shaft undercut. tighten the pinch bolt to 75 ft lbs. place the steering gear into position guiding the coupling bolts into the proper holes in the shaft flange. install the steering gear to frame bolts and torque to 66 ft lbs.install the coupling flange nuts and washers. make sure the coupling alignment pins are centered in the flange slots. tighten the nuts to 20 ft lbs. maintain a coupling to flang dimension of 0.250 - 0.375 inches. install the pitman arm.install the hoses. you are done except bleeding power steering system. BLEEDING POWER STEERING. fill the the power steering pump reservoir to the proper level and let the fluid remain undisturbed for at least 2 minutes. start the engine and run it for only about 2 seconds.add fluid as necessary. keep doing this procedure until fluid level stop dropping. then raise the front of vechicle so the front wheels are off the ground.set the parking brake and block both rear wheels front and rear. manual transmission should be in neutral. automatic transmission should be in park. start the engine and run it at approximately 1500 rpm. turn the wheels off the ground to the right and left lightly, contacting the stops.add fluid as necessary. lower the vechicle and turn the wheels right and left on the ground.check the level and refill as necessary. if the fluid is extremely foamy, let the vechicle stand for a few minutes.with the engine off and repeat the procedure. if fluid looks foamy. once all done.dont drive vechicle on highway until normal steering is obtain.
Apr 13, 2011 | 1987 GMC Suburban
Can you slide the transmissin away and replace seal
It would be nice to know what year & model.
But still not likely.
To replace the front seal If it is an AUTOMATIC, you must remove a lot of parts.
For front wheel drive the first thing are the wheels. Then drop the lower ball joints,break loose the struts from the tie-rods. In some cases lower control arms, sway bars, stabilizers,exhaust systems
The drive shaft(rear wheel drive) or drive-axles (front wheel drive),
transmission mount
cross-member (rear wheel)
shift rods or cable
hydraulic lines (if automatic)
inspection/access cover at bottom-rear of engine,electrical sensors(if applicable). Then the Bell housing bolts as well as torque converter bolts.
And THEN, because the torque converter holds the majority of your transmission fluid the transmission must be removed with the torque converter attached.Moved far enough away that the converter can be removed safely without spilling the fluid everywhere and where the removal & replacement of the seal can take place where as not to damage it during installation.
Some seals if aren't put it perfectly straight will kink the rubber and jeopardize the whole job.
And the worst thing that can happen after that big job is to have a leak. It must be done right without taking short cuts.
Its a $10.00 part but $300 -$1000 OR MORE to put it in.
Sep 18, 2010 | Plymouth Breeze Cars & Trucks
My transmission leaks what should i replace
There are at least 5 places on the Automatic transmission that can over time, and mileage develope fluid leaks. Front converter seal at the front of the transmission,pan gasket in the center,dipstick tube o ring at the center on one side ,speed sensor o ring,and the tail shaft seal at the rear,of the transmission.
Place a flat piece or huge card board,under the engine and transmission,after driving you will see where the fluid,red in color is dripping. Its easier to spot exactly where the leak is comming if you can look under the car,while it is running, The easiest leak is the pan gasket,the dipstick tube, and the speed sensor,then the rear housing tail shaft bushing and seal.
If the front seal(converter seal) is leaking the transmission will need removed,and the seal,and maybe even the front pump bushing Replaced,it would be a good idea to replace the bushing esp if it has high mileage,80,000 or 100,000 miles of use.Change the fluid and the filter,while repareing the leak or leaks.Is a good idea.
Sep 17, 2010 | 1995 Chevrolet Camaro
How to replace a rear transmission seal
Hi Friend: My name is David i'll be Assissting you today.
#1) First get you a Drain Pan put underneath truck where the Tail Shaft is located you'll loose some fluid when you remove the Rear Transmission Seal.
#2) You might need to Jack up thr rear of your Truck to give you more work space.And Secure your Truck with good jack stands and Also Put some Wheel Chucks (Blocks in Front of your front Wheels to prevent it from rolling forward on you.
#3) Next you'll need to remove your Drive Shaft, There are Four (4) Nuts on the Rear of the Drive line where it connects to your Rear End on the Front Side of 3rd Member.
#4) The (4) Nuts are Hold 2-U-Clamps 2- Nuts per Clamp, Take off the 4 nuts Tap the drive line with a Plastic Mallet this will loosen up the U-Bolts Save all your Nuts ,you'll need them to put back on the U-Bolts to get Drive line back in and Tight.
#5) You might have to use a small pry bar to FREE Up the Drive line Universal Joints and push the Drive line Forward just enough to get Drive line away from the Rear End.NOTE: becareful not to let the 4-Universal Caps come off the Universal Joint.Take some Black Tape and Just Wrap it Around ALL 4-Of the Caps to hold in place until your ready to put back in.
#6) Now Pull back on the Whole Drive Line Slowly and it will Come out of the Rear of your transmission.Thats where your Rear Seal is Located.
#7) Get the Proper Tool to Remove the Rear Seal from the Tail housing, (Seal Remover) and remove it from the transmission.
#8) Now Using a Seal In-Staller You'll line your new seal up to the Tail of your Transmission.Evenly And Tap your New Seal in ,it must be Tapped all the way in until its flush with the Tail Housing.
#9) Now you just Reverse the Removal Instructions( take Off the Tape) and put your Drive line back in. Just put your truck in Neutral so you can get the Rear Cups to line back up in the rear end.
#10) Make Sure you are lined up now put your U-Bolts back in.
And the Nuts on and Tighten up good and Tight.
Don't forget to put back the Transmission Fluid Lost.and after Starting Check and Make sure your Transmission Fluid is up to the FULL line.
This will get you back on the Road Sir.Thank You for Using FixYa Please let me know how my solution has helped you by Voting Thanks Again. From: d_hubbs
Aug 21, 2010 | 2004 Chevrolet Silverado
Transmission leaking through drive shaft
the rear seal on the tail shaft must have gotten damaged when you removed the shaft. it is available at any good parts store, easy to change. you have to pull the drive shaft back out, then you can use a small hook / prybar to pull the seal out, then tap the new one into place. pay close attention to the install height of the old seal before you remove it, so you know how far to drive the new seal in. good luck!
Mar 27, 2010 | 1996 GMC Sierra
Front wheel drive shaft is not all the way in from passenger side
take it back and have them put it all the way in. you should not be leaking fluid from there.
Jul 21, 2009 | 1998 Chevrolet Malibu
I have a Disco II and the wheel hub bearing went and i'm tryign to change it but i cant seem to get the hub off, can any one help with a step to step guide or something, thanks.
RAVE says the following:
1) Release ABS Sensor harness grommet from inner wing valance and disconnect multi plug.
2) Raise front of vehicle.
3) Remove road wheel.
4) Pull ABS Sensor harness through aperture into wheel arch.
5) Release harness from brackets on inner wing valance, suspension turret and front hub.
6) Release stake from drive shaft nut
7) Remove drive shaft nut with assistance & discard.
8) Remove front brake disk (Remove calliper, pad holder, screw and tap to remove)
9) Remove 4 bolts securing wheel hub to steering knuckle.
10) Release wheel hub from steering knuckle then remove wheel hub and drive shaft assembly from axle. DO NOT REMOVE ABS SENSOR FROM HUB. HUB AND SENSOR ARE SUPPLIED AS AN ASSEMBLY.
11) Position the wheel hub and drive shaft on a press, place supports beneath the wheel studs and press the drive shaft from the wheel hub.
12) Remove drive shaft oil seal from axle casing.
Refit is mostly the reverse, you need to take care to lubricate things in the right places and put loctite on the drive shaft and locate the loom and torque everything right.
Mar 24, 2009 | 1999 Land Rover Discovery
GM Buick lacrosse seal kit. front axle. front wheel drive axle shaft Logo
82 people viewed this question
Top GM Sport & Outdoor - Others Experts
Are you a GM Sport and Outdoor - Other Expert? Answer questions, earn points and help others
