Question about Hardware & Accessories
Need a manual for Stanley model 55 wood plane
Need a users manaul
    Sergeant:
  • 269 Answers
How can I fix or replace a broken wingnut on my Stanley No220 Block Plane?
Hi Steve. A cursory check on ebay shows you can buy one for as little as 7.00. I suggest buying one used or one being sold for parts. I had this same part broken on mine. They are cast metal and tend to break. From one wood worker to another, I'd highly recommend bumping up your game to a plane with an adjustable throat like the Stanley 9 1/2 adjustable throat plane. You'll thank me for the rest of your life! :)
Dec 09, 2015 | Crafts & Hobbies
Need instructions to program Stanley Model DR-1212
Timer is not identified.
Following link has wide variety of timers and manuals, including Westinghouse/Stanley timers
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Stanley Hardware & Accessories
How do I assemble a Stanley #5 Plane?
Jerry, you first want to take account of all your parts to make sure you have everything you need. If you feel you do have all the proper parts then you'll want to start with the BOTTOM, the part that contacts the wood when you actually use the plane. On the PLANE BOTTOM you'll need the FROG, with a few adjusting screws and levers. The FROG is a very important part of the plane, in that it provides a surface to which other parts of the plane are attached also..you'll be needing a long flat blade, sharpened and honed to a very fine edge. You should get these parts together and get as far as you can, then send me an email and I'll walk you through the rest of the assembly. Corky (fixitcr63@yahoo.com) ,
Oct 27, 2014 | Crafts & Hobbies
How do i assemble a stanley block plainer
1, Lay pencil on the table top, place body of plane with the front (toe) resting on the pencil, so the light passes beneath the front and middle of the plnes body.
2, lay blade, bevel side up, in to body of plane, ideally sharp end is sticking out of the mouth ever so slightly., 1/2-1mm.
3, Release the knob or lever cam on the lever cap and place on top of blade.
4, tighten knob/turn leaver till it tightens on the blade. and your ready.
5, If the blade isn't protruding the mouth correctly then:
6, Loosen a knob/lever a little to allow the blade to just move, adjust the blade forwards/sidways, lock it in place by re tighten the knob/lever.
Plane a thin piece of wood, re adjust as necessary till wafer thin shavings collect in the mouth ontop of the bevel.
Aug 29, 2014 | Bailey Stanley 12-920 - Block Plane
Adjusting stanley block plane G12-060
Adjust the mouth opening by loosening the front knob, then turning the little lever under it to move the sliding "tongue". Adjust the iron extension by turning the rear knob - it should BARELY peek out under the sole. Adjust the iron\'s angle by sliding the rear lever from side to side. Adjust the iron\'s tension with the top cap screw.
As you plane, if your plane takes off anything thicker than a single layer of toilet paper, the iron is extended too far. A block plane is not a tool to take off big hunks of wood, it\'s a tool to very slightly shave a wood surface, one thousandth of an inch at a time. As such, it needs to be crazily sharp, sharpened to your best approach to perfection. Please read about "Scary Sharp" on the Internet.
Jan 15, 2014 | Stanley Crafts & Hobbies
How to adjust
Those are funny little planes - they're wicked handy when you need one. I like mine a LOT.
They ARE coarsely built, not a "fine" tool, but they do a fine job.
Loosen the little screw SLIGHTLY, then either bump the rear of the iron (to extend it more) or the rear of the plane (to extend the iron less) against a piece of softwood (bench, sawhorse, 2x4, hammer handle). When it's where you want it, tighten the little screw again.
Adjust the plane's mouth (assuming that you're using it as a bullnose plane, not as a chisel plane) by loosening the big screw, then just sliding the bullnose front & rear.
Remember - planes are meant to SHAVE wood. The iron should NOT take off a thick shaving, it should take off a shaving no thicker than one sheet of toilet paper. The iron should BARELY peek out from under the plane.
Jan 14, 2014 | Stanley 12 - 975 Contractor Grade Bull...
Need manual stanley lightmaker 360-3057
Copy following links for possible timer manual:
Stanley timers are generally made by Westinghouse, and possibly manufactured by Tork.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westinghouse
http://waterheatertimer.org/Woods-timers-and-manuals.html#46-1022
Jun 29, 2012 | Stanley 31200 TimerMax Indoor Weekly...
Need a user guide for setting a Stanley 3120 Indoor timer for Lamps
Possible instruction manual appears on following link.
Add a comment and say if one of the manuals fits your product.
If manuals do not match, then add a comment and describe timer in detail for possible help.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
Sep 19, 2011 | Stanley 31200 TimerMax Indoor Weekly...
I need an instuction manual for a plane that is over 100 years old. Stanley no 45 plane.
Something like this? http://www.tooltrip.com/tooltrip9/stanley/comb-planes/45man.pdf
Jun 15, 2011 | Garden
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
