Question about Drills
My RYOBI cordless multi tool just stops working randomly..Batteries are full y charged.Model no RMT1801
Model Number RMT1801
    Genius:
  • 2,494 Answers
Check brushes in the drill.j
Posted on Nov 08, 2014
danny_murray
  • 55 Answers
SOURCE: Charger not charging
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Posted on Dec 04, 2008
  • 583 Answers
SOURCE: Delta cordless power tool batteries, #CL180B
battery world or the like will be able to supply new ones or repack your own
Posted on Nov 17, 2009
lcdpayless
  • 25 Answers
SOURCE: my ryobi 14.4v cordless drill won't turn on. The
use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Posted on Jan 29, 2010
Editor925
  • 285 Answers
SOURCE: What Ryobi batteries p103 or
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Posted on Feb 24, 2011
SOURCE: my 18 volt Ryobi battery shows charged in charger
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Posted on Aug 15, 2012
What is the best way to store the new ryobi 18v battery
Is your ryobi 18V battery is a Li-ion battery? if so you can store it with 40% power and keep it clean, cool, and dry. Then every 1-2 month to charge and discharge the battery for once time.
More battery tips or batteries and chargers for cordless tool you can come here:
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Nov 02, 2014 | Drills
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
Why did my ryobi multitool stopped working?
I have not ides of your question, do you mean your tool can not work or your tool's charger can not work?
Please give the tool model number, battery part number and charger model number when asking the questions, otherwise, no one can help you.
Jun 19, 2014 | Ryobi Multi-Volt Battery Charger
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Dead power tool battery
You can learn how to bring your Nicad cordless power tool batteries back to life with Battery Resurrection.
A simple procedure will enable your Nicad cordless power tool batteries to again charge in your battery charger and give their full power potential. Works for ALL Nicad batteries including Dewalt, Makita, Craftsman, Skil, Ryobi, Milwaukee, Firestorm, Versapak, Black & &Decker,Coleman,Bosch,Porter Cable, Fein,Hitachi and more.
Battery Resurrection is a registered trademark of Unique Dynamics Inc. Check it out below:
http://www.batteryresurrection.com/
Testimonials from hundreds of users: http://dewalt-battery.uniquedynamics.com
Oct 06, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
Wont charge
One thing I have found with the ryobi 18V batteries in particular, and cordless tool batteries in general, is that if the battery is completely dead, the charger simply will not recognize it. This is referred to as a "threshold level" by some manufacturers. One solution that has worked well for me in the past is to take a battery that is known to be good and has a charge and use small jumpers to hook it to the problem battery, terminal for terminal, for about 1 to 1 1/2 minutes, much like jumpstarting a car. Then place the problem battery back in the charger and more often then not, it will take a full charge. Wear safety glasses any time you're messing around with batteries, because although the risk of explosion is minimal, it is still a risk.
Aug 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
Oct 22, 2009 | Ryobi Drills
14.4v cordless drill...battery does not get a full charge
Batteries retain a memory. If you only drain the battery half way and than recharge all the time it will only keep half a charge. Try running it all the way down and than recharge it, this can take some time. Let it run till it gets very very slow and almost stops, but don't go past where it stops or it will not take a new charge at all. It does not always work, but worth a try before buying a new one. Good Luck
Jul 10, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Nov 25, 2008 | Hand Tools
Drills Logo
155 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
