Question about Dryers
How to connect a new 4 wire plug to an 3 wire dryer with different color wires?
New 4 plug purchased at Home Depot has black, red, white and green wire connection however the Maytag Ensignia dryer model MDE6657BYW has blue & brown wire on the left, 2 white wires in the middle and black & yellow wire on the right. With the new 4 plug what do I connect the black, red, white & green wires to on the 3 connections on the Maytag?
mikedurland
  • 481 Answers
SOURCE: I have to change the
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Posted on Jul 02, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
carldc3
  • 82 Answers
SOURCE: I am converting a 3
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Posted on Jan 05, 2009
  • 42 Answers
SOURCE: amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Posted on Jan 27, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
How to connect a plug electric dryer to a 4 plug outlet
for short, just dont mind the color.. the black wire from the new plug goes to right in/on the appliance terminal block, the white from the new plug goes to both white in the middle of the same terminal block and the red wire from the new plug goes to left terminal block of the appliance therminal block and of coarse the green from the new plug goes to the appliance frame.. no need nor sense in trying to figure the wire color of the appliance as it does not mean anything really and it does not follow any rules nor standards..
Nov 08, 2014 | Dryers
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
I need to change the dryer power cord on my Amana NDE6800AYW dryer. The current cord is a 4 prong with four wires that are black, red, green, and white. I need a 3 prong plug and I got a cord a Home...
Jul 17, 2009 | Amana NDE6800AYW Electric Dryer
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
Electric cord
What you should get is a new 4 wire cord. It is way less complicated than trying to change out the wall receptacle.
On a 4 wire dryer cord you have White(common) in the middle. Red and Black are hot and go on either side of white. If you really want to make it look good you can put red to red on the terminal and black to black but you don't have to. Some dryers may not have those color hot wires. Green hooks to the chassis with a green screw or any screw connected directly to the frame.
Jul 21, 2008 | Kenmore 62802 Electric Dryer
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
