How can I disable the incessant end of cycle beeping of a Haier ENCORE washer and dryer?
MAKE THE BEEPING STOP.PLEASE IT IS DRIVING ME CRAZIER.
  • 1294 Answers
SOURCE: End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Posted on Nov 27, 2007
  • 4 Answers
SOURCE: E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Posted on Mar 08, 2008
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Posted on Feb 04, 2012
My spin cycle is not working
could be many things, motor, broken belt or drive gear, it is not easy to diagnose or fix if it's old get another, if not get a technician.
Jul 12, 2015 | Haier RWT150AW Top Load Agitator Encore...
How to reset my haier dryer
Pull the plug. Reconnect after 30 seconds. If there is a fault you need to fix the fault first as the fault will continue to stop the dryer. Faults may be solved by reading the troubleshooting section in the user manual.
Jul 12, 2014 | Haier GDE750AW WHITE 7.0 CU. FT. ENCORE...
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
Jul 09, 2012 | Haier Dryers
Incessant end of cycle beep. Can I stop it? My new Bosch shx68p05uc drives us nuts. My 88 year old mother-in-law sleeps near the kitchen and I cannot run this dishwasher at night due to this darn...
Welcome to FixYa.
To turn the volume down of the signal or to turn it off entirely is as follows...
Hope that solves your incessant beeping problem. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided here as well as a brief testimony is appreciated.
Regards,
Macmarkus :)
Apr 19, 2011 | Bosch SHX68P05UC Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
To Enable or Disable the Cycle Completion Signal...
1. Open the door, hold down the “Quick Wash”
button and simultaneously turn the Dishwasher on.
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it
doesn’t beep, it means that the Cycle
Completion Signal has been disabled.
3. Turn the Dishwasher off to take it out of
program mode.
I hope this answer's your question. Thank you for choosing "fixya".
Please rate the solution favorably if indeed it was helpful, if not please let me know.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
We have the Haier XQG50-11 Combo VENTLESS Washer / Dryer 120 Volt and the problem we are having is that the clothes are not drying. The dryer itself gets plenty hot but the clothes are wetter at the end...
make sure your drum is turning,open it quickly and see if it's turning,also make sure you have good ventilation behind the dryer,let me know what you find-mike
Oct 15, 2008 | Haier Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
