Question about Sewing Machines
I can't get my buttonhole worker to work. I don't know how to set the pattern#, also I can't set the buttonhole worker right. I have read the booklet, but I don't understand. W
I can't get my buttonhole worker to work. I don't know how to set the pattern#, also I can't set the buttonhole worker right. I have read the booklet, but I don't understand. What it wants me to do.
    Novelist:
  • 143 Answers
Ah, might help if you gave the make and model number of the machine. There are so many, not all of them work the same.
Posted on Nov 19, 2014
5 Suggested Answers
Tally Girl
  • 1133 Answers
SOURCE: buttonhole pattern Wheh I select the buttonhole
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
Posted on Oct 25, 2011
SOURCE: pfaff 2144 won't stitch right side of buttonhole or skips stitches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Posted on Jun 11, 2012
  • 1564 Answers
SOURCE: My New Home HF-1012 buttonhole stitches don't work.
Take it back... and have him fix it again... this time ask him to tell you exactly what he did to get it to work.
Posted on Aug 30, 2012
SOURCE: Pattern selection dial
take the machine back & get another one
Posted on Aug 31, 2012
I set a buttonhole to auto and then when I try to repeat the sides don't line up. The bottom of the buttonhold ends up quite a bit below where it should have stopped and stops too far from the intended...
Generally, on the more advanced machines there's something called "balancing a buttonhole" or "balancing a pattern". A knob, that when adjusted, keeps the right and left sides of a buttonhole or sewing pattern aligned. Since I don't know what you've got, let me send you to look at that feature on a Juki F-600, as that's one of my machines that has a pretty common method of balancing: http://www.sewingmachinesplus.com/media/products/juki/hzl-F300/f-series-instruction-manual.pdf bottom of p. 71 (72 of the pdf)
Jan 02, 2014 | Bernina Sewing Machines
Brother XL5000 sewing machine won't do a 4 step button hole?
you didn't say if it's a mechanical or electronic sewing machine?
do you have a manual?
if you don't here is a link for one
http://www.manualslib.com/download/22168/Brother-Xl5000.html
does the machine have a buttonhole lever that you have to pull
down before you start the buttonhole?
Nov 15, 2012 | Brother Sewing Machines
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
My 4423 will not advance when I have all the settings set to sew a simple buttonhole. Why?
do you have the buttonhole lever pulled down?
if these suggestions don't help then the machine needs to be checked at a sewing machine shop
May 26, 2012 | Singer 4423 Sewing Machine
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
How to use the buttonhole attachment
You haven't listed the model of your machine so its hard to give you step by step instructions as there is variations in how buttonholes are done. Some machines have a 4 step sequence on a knob, it may be colour coded with a little buttonhole symbol.
Other computerised machines you just select the buttonhole style and pull down a lever behind the needle bar which lines up with the special buttonhole foot to trigger the return stitching down the buttonhole side.
Have a look in your accessories and see if you have a buttonhole foot like this
tally_girl_76.jpg If so, remove the current pressure foot and put this on, clip it onto the little metal bar you see near the front of the foot. Now put your button into the back ratchet bit of the foot, you pull it out, place the button in there and close it up firmly to hold the button in place. This helps to give you the right length buttonhole.
Now you need to start the buttonhole stitching sequence and sorry, but I don't know what your machine's is, you really need to check the manual for this bit. It may be a 1,2,3,4 sequence on a dial and probably stitch length set to 0.5 so its a closed up satin stitch.
But you stitch the butttonhole in the folowing sequence:
near bar tack, reverse down right hand long side, far bar tack, then back up left hand long side, then a couple of stitches in place to finish off.
The buttonhole foot will sit firmly on your fabric and the inner part of it will move backwards as the machine stitches, then comes back to the front again.
The computerised machines will have a little lever you pull down and these will trigger on a lug on the buttonhole foot to start the reverse stitching at the right length buttonhole. Sometimes they will stitch both long sides in the same direction too, so sequence is near bar tack, down right hand side, far bartack, then it will stitch back to front in little straight stitches, then do the left hand long side to the back and finish off.
On early machines, you actually set the stitch length to 0.5, and stitch width to 2 for sides and 4 for bartacks and made the buttonhole yourself by stitching down one long side, leaving the needle in the fabric and pivoting the work around, then stitching the bartack, then the other long side, then final bartack all manually. It can be done but obviously the new programmed ones are far easier and give consistently similar buttonholes on a garment.
ALWAYS, interface the fabric to be buttonholed, you'll never get a good practice buttonhole without interfacing in a sandwich between two layers of fabric so no point practicing without it.
And, never cut your buttonhole with the seam ripper unless you pin across the two ends first to make sure you don't have a woopsy moment and rip through the end bartack. I use a buttonhole knife and block of wood to cut and it ensures you never have a cutting disaster.
I also pull the thread tails through to the underside with a needle afterwards, tie them off and add a dab of fray stopper to make sure the buttonhole never unravels, then trim the ends off close.
I hope this helps you but obviously getting the manual to your machine would be a big help too.
Sep 21, 2011 | Husqvarna Sewing Machines
Don't know how to do button holes
Slide the back of the buttonhole foot "R" open, place your button in the cradle and slide the fott together so it holds the button.
Snap on the buttonhole foot on the machine. Pull down the buttonhole lever. It has a small white plastic paddle on the end and is located up and to the left of the needle bar. Pull the lever all the way down. Turn the pattern selector to Buttonhole. Place the tension on 3. Place the stitch width control on 5 or 6. Place the stitch length control a little below 1. Make sure that you have some stabilizer between the layers of fabric. Use freezer paper in a pinch. Lower the foot on your fabric making sure that the foot is not pulled forward or backward. Make a test buttonhole. AFTER EACH BUTTONHOLE YOU MUST TURN THE PATTERN SELECTOR OFF BUTTONHOLE AND BACK ON IN ORDER TO RESET THE MECHANISM. Make several test buttonholes, adjusting the width and length if needed.
Jun 02, 2011 | Janome D'cor Excel 5018
Not sure how to use the buttonhole foot J that came with my 712T machine. I guess I don't understand the sliding part. Are you suppose to guess at the buttonhole size or do you use the button somehow to...
The buttonhole foot slides open so that you may insert the button which you are making a button hole for so that it may be sized correctly.
Slide open the foot, place the buttin on the spot and slide it closed.
Turn the pattern selector off and back on to the buttonhole pattern to reset. (Do this each time you make a buttonhole to reset)
Pull down the buttonhole lever located up and to the left of the needle bar. Pull it ALL THE WAY DOWN so that it will be tripped by the buttonhole foot as it moves.
Set the stitch width to about 4 or 4.5.
Set the stitch length to a very tight stitch (but usually slightly higher than the recommended marking)
Set the upper tension on 3.
Use an appropriate stabilizer. This is the key to a good buttonhole.
Lower the foot on the fabric, ensuring that the foot goes down without springing forward or back.
Make a few practice buttonholes, adjusting the width and length untill you get what you are looking for.
Jan 16, 2010 | Janome MyExcel 3123
Tangled thread
Ask at the shop where you bought it, take a sample and arrange a time to meet & discuss if it is under warantee.
Jul 30, 2009 | Brother CS6000i Computerized Sewing...
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
