Hello, my bestec 250w smps is not working.can any one help me repair the faulty one .I am a qualified engineer.
Smps power supply for bell based desktop
    Sergeant:
  • 269 Answers
It is unlikely you can repair your power supply for less than a new one unless the problem is simply an internal fuse. Check Amazon, or eBay for possible replacements: eg. http://www.ebay.com/itm/170927157573
Posted on Nov 08, 2014
4 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: PC smps power supply problem
ok you open the pcb check the fuse first then replace it if faulty if it burns again then check 4 diodes then see if 200v big capacitor is expanded or not if so then replace it if not then check diodes after transformer if short then replace it
Posted on Nov 21, 2008
  • 17 Answers
SOURCE: Regarding 250W SMPS
250 watt is low under any circumstances, I'd upgrade atleast to a 450 or higher, around 650watt to be extra safe.
Posted on Jul 11, 2010
  • 40 Answers
SOURCE: power supply is not working this smps sulotion (
you must look at the diode or the resistor if the its working....
note: pls open first the Power supply and test it with the tester: then jumper it with the color green and black
Posted on Oct 13, 2010
It is likely cheaper/easier to replace the power supply. Look for a replacement through Amazon or eBay. For example: http://www.ebay.com/itm/170927157573
Nov 07, 2014 | Computers & Internet
How to repair the smps Bestec TFX0250D5WB
1) PROPERLY discharge the Electroytic Capacitors inside, BEFORE working on the unit.
The Electrolytic Capacitors used are Radial Aluminum Electrolytic Capacitors.
The large ones you see, are used in the Input Stage. They filter the incoming AC electricity.
These capacitors can hold a charge of Up To 100 Volts.
That is enough power to stop your heart. In other words -> FATAL
This of course does NOT make me want to post info, about possible repair on your Power Supply.
Above ALL, I do NOT want You to come to ANY harm!!
However I know that some situations require trying to fix a unit. It isn't always possible to go out, and but a new unit.
I just want YOU to be SAFE!
The Bestec units are of low quality.
1) Low quality Electrolytic Capacitors
2) Low quality Rectifier Bridge
3) Low quality Power MOSFET's
4) Lighter gauge of wiring, then what should be used
The Electrolytic Capacitors are the weakest link. Start with a visual inspection, and see if any are bad.
Using the direct link option does not seem to be available for me. Therefore you have to copy each link I will state, and paste it in your address bar. (http://) Then press the Enter key.
If you are unaware of how to do this, please post back in a Comment.
The same information for Electrolytic Capacitors on a desktop computer motherboard, can be applied to the Electrolytic Capacitors in your Bestec power supply;
A) http://capacitorlab.com/visible-failures/index.htm
B) http://www.youtube.com/watch?v=Lut7MX5Dd_A
C) http://en.wikipedia.org/wiki/Switched-mode_power_supply
D) http://www.hardwaresecrets.com/article/181
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 21, 2013 | Computers & Internet
My smps is working, but my power is not coming to the mother board
Replace the power supply or have it tested.
Amazon com bestec atx 300 12z You can get a replacement pretty cheap. Most all power supplies can also be tested - Bestbuys geek squad or a small computer repair shop should have the means to test it.
Feb 23, 2013 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
My computer shuts down
problem with you either capacitors on motherboard or capasitors in smps, 80 % it becouse of capacitors in smps, it's not providing sufficient power to motherboard.
Feb 26, 2011 | E-Machines eMachines Desktop PC
Regarding 250W SMPS
Jul 06, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Do not start
First remove smps power suply unit box from cpu.
Then ground pin and check is it on you have to ground 4-5 pin blck and green.
Then if it is on then smps is ok.then pull cmos cell from motherbord for 10 minutes make sure cmos cell give voltage.Remove pci cards from pci slot is any.
connect ATX power supply to motherbord then check.
But if smps is not turn on then it has some issue.
Change fuse of smps if still not on then you have repair it or change.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
HOW CAN I TURN ON A BESTEC ATX-300-12E PSU OUTSIDE OF THE COMPUT
check on mother bord there is power on key in corner of motherbord.
Some smps has switch in back side of it.
Mar 26, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
