Question about Home
How do I reset my atomic clock model W86111 to Central Standard Time?? it has not reset itself
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
  • 13 Answers
SOURCE: Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Posted on Mar 08, 2009
Singpianomom
SOURCE: I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Posted on Apr 06, 2009
  • 5 Answers
SOURCE: I need to change the atomic clock from military
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Posted on Jun 29, 2010
BillB-SA
  • 2761 Answers
SOURCE: Cannot get my atomic clock to reset to proper time
Make sure that it has fresh batteries, set it for the correct time zone, set the DST switch to ON (unless your time zone does not use DST), then place the clock on a solid surface, outside if possible, so that the face of the clock is pointed roughly towards Fort Collins, Colorado. It should reset in a couple of hours - or less.
Posted on Aug 07, 2010
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 | Home
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
How do I reset the time zone? I have tried to follow the directions with no luck.
Is the picture the type of clock your referring to? If so you cant set the time zone on that type of clock. You can change the time though.
Nov 05, 2014 | La Crosse Radio Controlled Atomic Clock
How to reset an atomic clock
Hello
Get into this site. You can select and see the user manual for your SkyScan atomeic clocks here. OK.
http://www.atomicclocksstore.com/manuals
Nov 14, 2011 | SkyScan 86709 Atomic Wall Clock
I have a SPC900 sharp atomic clock and I am having a problem trying to set it to central time zone?
I have a brand new Sharp Atomic Clock Model SPC900 and have gone thru the initial setup guide... I chose to allow the transmitter in Ft Collins, Colorado to set my Time and Calendar automatically however it has yet to set my clock after two hours now...Please help...
Tony
Nov 05, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Time setting for skyscan model 88202cop , to set correct time in central zone
The clock sets itself, I have never touched mine, it just works, and unless you are sitting on a time zone, it should work. There is a set button in the back , I have never messed with it, It has an alarm on it too. Hope this helps.
Jul 17, 2010 | SkyScan 86709 Atomic Wall Clock
I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
Atomic clock is 2 hoursfast
You need to reset it to YOUR time zone. The default on this model is Pacific Coast time so you must be in the Central Time Zone (2 hours ahead of Central). Instruction manual should show you how to reset.
Feb 09, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Sharper Image Weatherproof Atomic Clock Model OQ007
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Done.
Nov 03, 2008 | Audio Players & Recorders
Home Logo
257 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
