Question about Ovens
Early 1960's Frigidaire 24" Double wall oven not heating
Top oven lower heating element does not heat. Broiler element does heat. Tried swapping lower elements from top oven to bottom, element works in bottom oven so that rules out the heating element as the issue. Tested voltage going to element, Right side contact to middle, shows 120V, Left side to middle contact shows 0V. Tested voltage coming from all contacts on thermostat, both with oven on and turned off to identify inputs/outputs. Compared to working thermostat for lower oven and there is no difference at any of the contacts. So from what i can tell, the element is ok, the thermostat tested the same as the working termostat, so voltage is leaving the thermostat on both wires. I am assuming it is the connection from the thermostat output wire to the element connector, what else can i check?
  • Official Brand Answer
  • 2,267 Answers
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Posted on Nov 11, 2014
  • 1314 Answers
SOURCE: General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Posted on Dec 29, 2007
  • 145 Answers
SOURCE: Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Posted on Apr 18, 2008
  • 530 Answers
SOURCE: Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Posted on Jan 04, 2009
SOURCE: Frigidaire double electric oven #pleb30t8cc
I have seen and have had bad soldier connections on the relays to the boards. check boards.
Posted on Feb 10, 2011
SOURCE: Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Posted on Apr 05, 2014
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
Frigidaire wall over model number CGEB30S8AB1 is not heating. It is just the bottom bake element. I tried to replace the element but it is still not working. I can hear the relay clicking but it will...
I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
Works perfectly again !!
Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
Oct 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Apr 15, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Ovens Logo
123 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
