How to solve the error turn the main power on E202-0002?
My canon imageclass mf4412 laser printer showing the error turn the main power on. E202-0002.
  • 628 Answers
SOURCE: Canon imageCLASS D760 All-In-One Laser Printer system error
Check this link at Canon USA: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=9437
Posted on Oct 26, 2008
  • 240 Answers
SOURCE: Showing printer error 6A00
I just copy this solution for you to this link:
the solution is posted by BAB..
they have the same problem as you ..then this solution solve it..^^
http://www.fixyourownprinter.com/forums/inkjet/39177
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on May 19, 2009
old marine
  • 2101 Answers
SOURCE: I use a Canon ImageCLASS MF4350d Laser All-in-One
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
Posted on Nov 11, 2009
swamijan
SOURCE: canon image class mf4412 error code e301-0001
canon imageclass 4412
error e202-0002
Posted on Jul 30, 2012
SOURCE: My canon MF4412 is power on but display is coming turn the main power on E202-0002
my mf4412 printer displaying a problem e202-0002 and red button continue burning
Posted on Sep 10, 2012
MF 4412 is power on but coming turn the main power on E001-0000.how to solve this error
This is a heat related code. usually it happens when you have expeienced a power surge or outage. you will have to enter service mode .*28* then go to function then to error then to reset and activate,
Oct 27, 2015 | Canon ImageClass MF4412 Toner Black Repl -...
Error e202-0002 for canon imageclass mf4412 and showing turn the main power on
Please follow the link below and it will show you what is happening.
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/Canon-MF4412-laser-printer-error-quot-turn-the-main-power-on/td-p/40847
Nov 08, 2014 | Office Equipment & Supplies
E202-0002 what is problem
Check this link and the answer that they finally found was their problem - hopefully it helps you - Boots66
ok guys finaly i have found reason for this .
FK3-1153-000---- CONTACT IMAGE SENSOR ASS\'Y , I mean to say this lamp and strip was faulty ,We have replaced it and
printer is now functional...
Aug 13, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
E100-0001 error
When there is an error E100-0001
Thus with the PSU is OK, replace the formatter board (main board) does not bring results. Problem is the plastic laser sensor, which came out of the seat (mine). Such cakes ...
The same problem was solved by restoring the electrical contact in the connector J801 LSU (laser unit). Simply reconnect the cables and adapters!
Apr 06, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
Turn the main power on e806-0000 ifproblem persists contact dealer or service rep
CANON 6050, 6650, 8070, 8570 E801 thermistor, fusing unit, power supply, main board CANON 6050, 6650, 8070, 8570 E802 power supply or main board error
Jun 18, 2013 | Canon ImageClass MF4412 Toner Black Repl -...
Jun 24, 2012 | Canon Office Equipment & Supplies
108 people viewed this question
k24674
jasbo
jasbo
