What can I do to fix the problem?
SOURCE: Acer Aspire 3680 Notebook
It seems like your harddrive has given up the ghost or thrown out the operating system.Power up the machine and enter the bios (Press either Del,F1,F2 to enter) once in bios check the system can see the harddrive,9 If bios can,t recognise the harddrive then it,s dead, If it can then the next step is boot options and make sure it it booting from the harddisk.
If It is then see if there is a recovery progrom in the bios that will enable a system restore,If not then change the boot option to start with a Cdrom and put in the recovery disk that was supplied with the Pc.
When going through the process with the cd you will soon find out if the harddrive is corrupt or Dead.
When using the cd if the system
SOURCE: Computer stopped working - shows message "Failure Fixed Disk"
Do you get the failure when you are booting up your computer? if not when exactly do you get that problems you are having?
SOURCE: Acer Notebook D260 SCREEN broke,and now is showing
yes you can replace the screen check ebay for a replacement screen
