Question about Amana Refrigerators
Amana Frig ABB2224WEB1 leaking water on floor. removed lower panel that covers the wheels. I do not see a drain pan to empty. Is there one? If it is the defrost drain hose plugged up how do I find tha
Amana Frig ABB2224WEB1 leaking water on floor. removed lower panel that covers the wheels. I do not see a drain pan to empty. Is there one? If it is the defrost drain hose plugged up how do I find that a unplug it? bought this unit March 2012
    New Friend:
    Problem Solver:
  • 10 Answers
Pam, the drain pan is locked under the refer. It can't be removed while the refer is upright. The problem and solution depend on if you know a do-it-yourself person. Part of he problem is most likely the TIMER located on the inside back/top of the refer. behind the plastic and metal shield. The other culprit associated with this problem is in the freezer, behind the metal backing, called the THERMOSTTA. I recommned repalcing both at the same time. enter your model number into partselect.com and identify the part, or its time to call a REFER repair man. A turkey baster with a small plastic hose attached (any hardware store) can siphion the water out of the tray, or a towel on the floor until you fix the problem,
Posted on Nov 08, 2014
tborn6
  • 700 Answers
SOURCE: so water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Posted on Jan 27, 2009
farfield
  • 462 Answers
SOURCE: Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Posted on Mar 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Water leak from my Kenmore refrigerator
Your problem is most likely a clogged drain line. Which is located in the back bottom of the freezer a little hole. Run some hot water down it with a spray bottom and it should resolve your issue. Also yes a Tech will be able to fix this problem
Posted on Jun 01, 2009
woodchuck789
  • 4070 Answers
SOURCE: About every 2 months the defrost drain gets plugged
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Posted on Jul 01, 2009
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My automatic defrost freezer in my frig does not drain the water down to the drip pan. Instead the water is coming through vents inside the frig directly under the freezer. this is an older Amana. We...
If the drain isn't stopped up than the water isn't draining into the drain.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Aug 11, 2011 | Refrigerators
I found water under my amana refrigerator Model Number ABB2222FEW does this model of refrigerator have a drip pan to catch water I can not find any reference to a drip pan in the book I received when I...
Hi
Look on the ceiling in the back by the compressor do you see a small hose on the ceiling. There's an access panel at the lower right corner. That's where it is ,there's a drain pan just under the hose remove that panel its right there.
Also check this link to have a detailed idea:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Amana Refrigerators
Where is the drain located in the amana refrigerator that empties the water into the bottom drain pan? ModelTC20E-L Amana frigerator
Good day,
In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Jul 26, 2010 | Amana ARB8057CSL Bottom Freezer...
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Whirlpool drain clog
yes it is most likely the drain that is plugged and or frozen up. to repair this you will need to remove the rear access cover inside the freezer compartment clear all the ice from the drain pan and flush hot water thru the drain hole located in the drain pan. this is a fairly easy repair you can do youself. the hardest part will be removing and reinstalling the rear cover. good luck peyton.
BTW I use a turkey baster or large syringe filled with hot water to flush the drain line with.
Jul 04, 2009 | Whirlpool ED2FHEXMS Side by Side...
Amana Bottom Freezer
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator
This is the most common thing on this site for refers. Its the drain line that takes water from the freezer when it defrosts to the pan underneath the appliance. You need to locate the drain line and remove the obstruction, sometimes its frozen so a short thaw may be helpful. The way I do it is I find the drain hose at the bottom of the fridge where it drains into the pan. I then connect a hose to it and blow compressed Co2 into the line. When there is no back pressure, I know its clear.
Dec 27, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
74 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
