Canon 2870 image runner. Paper jam error. But no paper was jamed. How to clear this error
    Top Expert:
  • Office Equip... Master
  • 46,690 Answers
Sometimes switching the machine off at the machine and switching back on will clear a code fault.
Posted on Nov 08, 2014
SOURCE: canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Posted on Dec 23, 2008
babaprithi
  • 372 Answers
SOURCE: my Canon Image runner 2318
is this problem only when u copy from the tray or even from bypass.if it is from tray only then ur rubber feedrolls needs to be cleaned with simple wet cloth.if it is from both then u have to check the paper path sensor
Posted on Jul 15, 2011
  • 8 Answers
SOURCE: when feeding paper through top
clean all the rollers with a little soap and water then dry them. good luck
Posted on Aug 22, 2011
canontech
  • 1219 Answers
SOURCE: canon image runner 2870, so
where do You getting the paper jam?
This model is known for the poor pressure between lower door and paper vertical roller.
Please send more info.
You can also contact me over emma.servis@gmail.com for service manual.
Posted on Sep 20, 2011
biotecfoods
SOURCE: Canon Image Runner C2058: Paper keeps being jammed
If you've been printing on pressure sensitive paper, residual adhesive (inspite of the backing remaining in place) can adhere to the top of the last exit. I use mild orange oil cleanser and a paper towel to clean the top of the feeder inlet. After that the "accordion paper jam" stops.
Posted on Jul 30, 2014
How to clear paper jam error in canon 2870 copier
Clear all the broken or hidden pieces of paper by removing the cartridge and paper tray......insert the cartridge and paper tray.......then..... switch on......
Nov 07, 2014 | Canon Office Equipment & Supplies
A4 paper jamed in teh finsher
Go To Below official Canon Printer Page For Your problem, http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Mar 19, 2014 | Canon Ir 3300 B/w Copier image Runner...
Canon image runner 2870, so many time paper jam.
Sep 20, 2011 | Canon imageRUNNER 2870 Copier
My image runner reports paper jam and i have followed steps on panel to clear it but to no avail
Is there paper stuck in the fuser? Sometimes you will have to remove the fuser usit and break it apart to clear the jam. Depending on your skill level this is better left to a technician.
Jan 11, 2011 | Canon Image Runner 1630 Copier Copier
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
Canon image runner 3200 false paper jam
First check all the tray's and make sure the papersize dial inside the paper cassette is set on the correct papersize,this is the most causes for false paper jams.Open and close all covers machine will send a reset data.Switch the machine off for 3 minutes untill it shows offline on the server and switch back on.
Dec 08, 2009 | Canon Computers & Internet
Canon image runner COPIER
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon imagerunner 2230
YOU HAVE A PROBLEM WITH THE PAPER FEEDING CENSOR. IT COULD BE OUT OF PLACE, BROKEN, A PEICE OF PAPER STUCK OR PULL OUT THE DRAWERS MAYBE PAPER STUCK INSIDE. GOOD LUCK
Aug 04, 2008 | Canon Image Runner 3320I Copier
jasbo
jasbo
