Question about Shark Navigator Lift-Away Professional Plus Upright Vacuum
My super turbo doesnt work anymore....no increase in engine revs and doesnt pick up fluff cotton or any other hard to get bits. What do I do??
    Genius:
  • 2,494 Answers
Check for blockage in machine.
Posted on Nov 08, 2014
I replace water pump and thermostat no coolant flow 2003 audi a4t
Check if the water pump works first. What was the reason for changing both?
Jun 06, 2014 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
Steam is escaping from underneath the iron, how to fix this?
Household irons can drip and spit out liquid water from the holes in the metal sole plate instead of producing steam if you have set the temperature too low. The obvious remedy is to increase the temperature, but this setting is not appropriate for all types of fabric. For example, the highest setting is generally recommended for removing wrinkles from cotton garments, and the lowest setting is generally safe for silk garments. Using the iron and its steam functions as the manufacturer intended can reduce or eliminate dripping. If that doesn't solve your problem, consider additional steam iron troubleshooting.
May 16, 2014 | Rowenta Irons
Cannot get black stains off with the cleaner kit from Rowenta that I bough at Bed Bath and Beyond. Used almost all of the cream and still not clean. adjina39@aol.com
Are you heating up the soleplate first to get it really hot, then put on an oven mitt to protect your hand, squirt cream onto a folded pad of clean cotton fabric, then apply to iron sole plate, rub over stained area gently, wait, then rub off. you may want to rub the whole iron sole onto a piece of waste fabric to remove the burnt bits. Itcan take a couple of goes to clean. The ironing press cleaning sticks work well too.
Nov 03, 2013 | Rowenta Irons
The togel switch does not illuminate nor does the iron come on
switch it on as normal ...put control onto hot ... whilst holding iron handle bang it on to hard surface that should sort it.. u get fluff stuck between the stat contacts. hope this helps. BSC APPLIANCES 07779933829 uk
Feb 25, 2011 | Rowenta DG5030 Iron
Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
May 29, 2009 | Sunbeam Steam Master 4055 Iron
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
My yamata fp202L
Most likely it is the fuse that regulates the heating element on your press that has burned out.
All you have to do is open the top, remove the heating plate. The fuse will be on the left, button shaped.
Replace the fuse and put everything back together and the unit should work.
You can buy a fuse from the company you bought your press at or contact the manufacturer.
Sep 10, 2008 | Yamata FP202L Cordless Iron with Auto...
Shark Navigator Lift-Away Professional Plus Upright Vacuum Logo
48 people viewed this question
Top Shark Irons Experts
thinksewfast
ray gallant
Tom Chichester
Are you a Shark Iron Expert? Answer questions, earn points and help others
