Phillips Magnavox 50mf231d/37 - Televison & Video
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Would love to be of assistance, but ...
When posting any question please be sure to include the make (brand), model plus any symptoms of the problem so that we may better help you with the problem. Thanks.
Posted on Nov 08, 2014
  • 35 Answers
SOURCE: magnavox 50mf231d/37
The clicking is the Stby relay. Your fault is on the PSB. Change the 1000 UF 10V Capacitors PSB with no more than 8V above the current rating. There are two of them side by side. Yuu can get new caps at radio shack or frys rtc. Get polar electrolytic caps with 105 C heat rated.
need some help email me
gysgt2u1@yahoo
Posted on May 08, 2009
SOURCE: 50mf231d/37 magnavox plasma
OK I have just taken care of both of these problems and now I want to share it with you DIYer's. As for the blinking red it is a software upgrade...go here...http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=PLASMA_EXTRA_LARGE_GT43_SU&grp=TV_GR&session=20090902212032_75.92.128.105&ctn=50MF231D/37&mid=Link_Software&hlt=Link_Software....and download the software to your PC. Then unzip it to a USB flash drive. Power off your TV. Stick the flash drive into your TV's USB slot, found on the left side, facing the TV. Power it up and let it do it's trick. Pull out the flash drive when instructed. That's it.
Now for the power problem. I noticed that my TV was taking longer and longer to fire up. Once on it worked great. Well this morning it didn't come on. I heard the usual relay click then a few seconds later...two more clicks and nothing. The green LED stays lite but it's dead in the water. So I started surfing the web for common problems found with this particular model. I came upon this forum and saw something about a couple of capacitors. So I decided to look into it. I purchased the service manual online for around $8.00 at https://www.completeservicemanuals.com/philips/magnavox/plasma-television/50mf231d/37-service-manual/prod_677.html. Not that I thought I would need it but it doesn't hurt to have it. So I took my TV off the wall and placed it on my bed face down. Be very careful because this TV is heavy!!! You will need to remove the stand or wall mounts first. Then there are 44 screws holding on the back, 32 long and 13 short. Pull the back off from the top of the TV first, set it off to the side. Now your looking at the workings...in the center is the power supply board. Oh yea please make sure you unplugged from the wall. There are 8 wire connectors to the board, 5 of them come off by squeezing the clip on the back, the other 3 just pull out. OK, there are 8 screws holding down the board to the chassis. Before lifting the board, locate the capacitors first. If the top of the TV is away from you and the bottom is near your knees (assuming it's on your bed) look at the center bottom of the power board. Locate two capacitors that are identical and side by side. Their values are 3300uf 10V. I found that these two buggers were raised on top, kind of bubbled. (if needed I have pictures of the power board, email dstafursky@yahoo.com). I picked the replacements up at a local electronics store for less than $5. I simply replaced them and reassembled the TV. It works killer just like when it was new.
Good luck.
Posted on Sep 03, 2009
  • 541 Answers
SOURCE: blinking red light on magnavox 50
You would be better off to have a shop check it out. Try unplugging it for a while just to reset everything.
Posted on Oct 14, 2009
dave1645
  • 834 Answers
SOURCE: i have a Magnavox 50MF231D/37 plasma tv that won't
you have some bad caps on the power supply board these can like devices will have a puffed up top where it vented the value is written on the side of the part
Posted on Nov 24, 2009
SuperTech-11
  • 1591 Answers
SOURCE: I have a Magnavox 50mf231d/37
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
Posted on Aug 24, 2011
Magnavox 50MF231D/37 4 BLINKS What is fix?
Could be an open internal fuse or power supply failure
Jul 25, 2016 | Magnavox Televison & Video
Software upgrade Magnavox Model 50MF231D/37
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Jun 05, 2016 | Magnavox Televison & Video
Need stand for a 50MF231D/37 tv
Contact the authorized dealer for Magnavox.
Nov 26, 2013 | Magnavox Televison & Video
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Jul 12, 2009 | Philips Magnavox 27MS343S 27" TV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
