Question about Garden
My carb has a white valve protruding from it with no attachment. If I depress the red bulb, air flows from the valve. what is the valve for and where is the attachment?
It could possibly be the overflow return port for the carb. If so it should have a hose going from it to the fuel tank. You shouldn't have any open ports on your carb.
Posted on Nov 08, 2014
SOURCE: I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Posted on Mar 27, 2009
SOURCE: Looking for a parts supplier to source Murray push mower 22'' deck
Well I have looked at my suppliers and they are showing it no longer available. So you may have to search around and find an old murray mower that no one is going to fix but has a good deck. good luck.
Posted on Sep 29, 2009
SOURCE: Murray 22'' 6.0 hp gas lawnmower engine dies right after start up.
SOUNDS LIKE YOU NEED A FULE FLUSH AND CARB KIT
Posted on Sep 30, 2009
SOURCE: briggs & stratton engine will not remain running
You have one of the infamous automatic choke Briggs carbs. These are supposed to close that butterfly that you describe, which is actually the choke until it is running, then it's supposed to keep it open. The problems is, if the diaphragm in the carburetor starts getting hard, or leaks, it'll kill the operation of the choke. They are known for their unreliablility to the point of where it's a shock to find one that actually works. You can fix it by replacing the diaphragm inside the carburetor, or by putting a spring on it that holds it open unless you manually choke it to start it.
Posted on Mar 29, 2010
SOURCE: Murray Walk behind mower, Model # 20705X6M 5.5
Clean ALL the very small holes in the brass bolt that holds the carb bowl on.Some are VERY small and easily clogged. With bowl off and the bowl float hanging free, does gas readily flow? It should, and it should of course stop when the float is raised (putting the needle valve on its seat). If this event is occuring, then the main jet must be badly clogged. If no gas even gets into the bow. (not enough details).. then there is a vacuum lock or something strange going on in the fuel tank (cap). The threads of the fuel cap on a mower allow it to vent, preventing vacuum lock of the fuel flow.Start at the tank and go back in. Please repost as this is a good one.
Posted on Aug 18, 2010
Sep 05, 2016 | Murray Garden
Aug 18, 2014 | Mtd 22" Yard Machine Push Mower
Feb 26, 2013 | Murray Garden
Jun 10, 2012 | Garden
Sep 17, 2010 | 1982 Suzuki Gs 550 L
Sep 27, 2009 | Garden
Sep 10, 2009 | Mtd 22" Yard Machine Push Mower
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 09, 2009 | Garden
Mar 27, 2009 | Garden
Apr 23, 2018 | Garden
