Question about Canon Office Equipment & Supplies
In canon ir7105 drum cleaning lamps is not working
I check cleaning lamps in another copier it is working.
    Champion:
  • Canon Expert
  • 234 Answers
Check the wiring,how the power come to the lamps,looks like it doesn't
Posted on Nov 26, 2014
muleskinner2
  • 270 Answers
SOURCE: canon NP7130 copier
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Posted on Nov 13, 2007
fer_nan_14
  • 76 Answers
SOURCE: Canon C3200 imagerunner
go to service mode By pressing * 28 * and you will see a menu COPIER then MISC
Posted on Dec 09, 2008
  • 117 Answers
SOURCE: canon iR 2016 copier problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Posted on May 07, 2009
  • 11 Answers
SOURCE: How to remove drum scretch from Canon 6045 Copier
you cannot fix a line of a drum. If the drum is causing a line on copies you have to replace it. Any light or fingerprints can cause further problems. Look online or at your local canon dealer for the drum unit.
Posted on Oct 20, 2009
iservice
  • 318 Answers
SOURCE: canon ir7105 finisher unit is not working..!
The finnisher is only in disable by a a disable funcktion that switch the finnisher off.It just need a reset in the service mode.I am not alowed to give service info on the net.Ask your local service centre to clear the funcktion for you.You dont have to replace the finnisher.This is normally a paperjam or a opstical that prevented the trays to move up and down.Then the finnisher go to disable funcktion
Thanks for you support
Posted on Dec 13, 2009
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
Canon iR7105 Errar E000065-0000
Please go to service mode and click on option, there you will find a option as wire cleaning. switch off the option by putting the opposite no.
basically you need to switch of the primary corona wire cleaning as off mode. If there is 1 in option make it 0 or if there is 0 make it 1.
Oct 11, 2015 | Canon Office Equipment & Supplies
202-001 what is problem this error modle no ir7105
This is a scan problem, Please check: scan switch, scan motor, or image processor board.
Thank you.
Jul 22, 2014 | Canon Gpr19 Ir7105/7095 Black Copier Toner
Canon ir 7086 error e012
DRUM MOTOR OR SOLID WAST IN DRUM UNIT (PROCESSING UNIT)....OR DISCONNECT AND CONNECT ALL DC CONTROLER JACS
Apr 15, 2014 | Canon Ir7105 Ir 7105 Copiers1saddle Stitch...
I have the canon np2020. We have replaced the drum unit, but the printed paper still comes out with black smudges all over it. What can the problem be?
any time u are changing drum try and replace the cleaning blade, remove the drum unit remove the drum, the blade, blow the unit with air blower, check the copy lamp and the lamp regulating board
Aug 24, 2010 | Office Equipment & Supplies
I found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
How do you lock a canon ir7105 for transit?
put a sheet of paper on the bed underneath the drum(very expensive part) apart from that unless you are shipping over seas you should be ok
Nov 09, 2009 | Canon Office Equipment & Supplies
Canon ir7105 photocopier
are you talking about the username and password to login to the canon tech support page @ support.cusa.canon.com? If so, this is for certified technicians only. I would NEVER give my personal info for this, but, if you present me with your problem I will get you the answer you need. I am very familiar with the ir7105.
Mar 07, 2008 | Canon NP 6551 Black and White Copier
50 people viewed this question
old marine
old marine
