Check my phone no.? - Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Would love to be of assistance, but ...
When posting any question please be sure to include the make (brand), model plus any symptoms of the problem so that we may better help you with the problem. Thanks.
Posted on Nov 08, 2014
Check line cord phone mean
The cord or cable connecting the phone to your pstn line is called line cord. check the connection at the back of phone and the wall jack. if it is ok change the cord and check.
Jul 20, 2013 | British Telecom Synergy 2110 Cordless...
Tip
How to Check Your Cellphone Model Number
  • For Nokia : Check Off The Battery and look Inside The Phone Or Write : *#0000#
  • For Samsung : Reboot The Phone and the model appears on startup
  • For Sony ericsson : Check Off The Battery And Look Inside The phone
  • For Sharp : Check Off The Battery And Look Inside The phone
  • For Motorola : The Model Number Writed On The battery And Inside the Phone
  • For Siemens : Check Off The Battery And Look Inside The phone
  • For Pocket Pc (Phone) : Writed in the back off the Phone
  • For alcatel : Writed In The Back Of The Battery
  • For LG : Check Off The Battery And Look Inside The phone
Thanks , Fix-shad0w
on Jul 07, 2010 | Lands Phones
Tip
How to Check main causes of Hissing Noise on phone line ?
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
***Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
on Jan 22, 2010 | Cell Phones
My phone seems dead although the computer connection and the fax are working. Help!
First try a new phone cord and a different phone. Are all items attached to one jack with one phone number? If you have multiple jacks, check if the phone works on another jack. If you have separate phone lines, check if the phone works on the computer/fax line. Check if the phone works without the other devices (particularly if daisy chained). Swap out all of the cables in the chain if it works directly.
In the multiple line case, if your phone works on one line and not the other, check if a phone works on that line at the incoming service. (If you are lucky, the incoming service has RJ-11 connections and you can test this yourself. Otherwise, you'll need a service person.) I've had several cases where mice or something broke one of two incoming phone lines outside so I just lost that one phone number. If the outside service doesn't work, call your phone company. They will fix it for free. If the outside service works, check your jack for loose wires. Check any exposed wiring in the house for damage. If the wiring isn't damaged in the exposed areas or at the jack, you'll probably need a service call (for a fee).
Checking the jack and wiring also applies if the phone works at one jack and not another.
If another phone works and the AT&T phone doesn't, check if the power adapter is plugged in and warm or cold. If the power brick is cold, then replace the power supply. The information on the type of power supply is usually listed on the bottom of the phone. Since this is a corded phone, it should work even without power, but sometimes, it won't. If the power is good to the phone, then replace the AT&T phone. Unless it's under warranty, it isn't worth getting them serviced. They aren't meant to be user serviced.
I hope this helps.
Jan 18, 2011 | AT&T 1855 Phone
I can't do outgoing calls, when i will start to call to my friends, after a second become call ended. Please advice, I already check the settings in my phone, but it doesn't work.
hi..
  • remove your sim card and put it on another phone and check whether it works or not..
  • If works means problem in your phone,call to your customer care and ask what change you can made in your phone...
  • else in other phone also it should not working means its a network problem ,consult your particular service provider may be they can block your sim for particular time..check
  • and also check take another sim card put it in your phone whether the call goes or not.. check it...
  • these are the reasons can occur for this type of errors...
  • and check in your phone the call settings if it okay are any diverts can occur...
  • check it...
If it's useful for you means plz rate me the 4 Thumbs ....
Jan 06, 2011 | Cell Phones
Tip
What to look out for when you want to buy a second hand/fairly used phone
Since you are not the first to use the fairly used/second hand phone, you need to be careful before you purchase it because it might be faulty and maybe that's why the owner wants to sell it.
These phones are funny sometimes because it might work well before you pay for it and by the time you get home, the fault of the phone might begin to show up.
Its also not advice-able to buy a second hand phone on the street or from someone you don't know too well that just convinced you to buy the phone. If such phone is faulty, you might not get the person that sold the phone to you or you might even see the person and he/she denies that they never saw you before. That's why its good to have a particular customer you buy such phones from after past successful transactions.
You will find below, factors to be considered before paying for Fairly used phones:
  1. Before attempting to buy the used phone, check other varieties of phones the seller has and see if three or more of these phones reach the standard of the particular one you want to purchase, so that if need be that you return the phone, you can still choose from other phones that has the same standard.
  2. Feel the phone and look at it very well if the case/phone cover has not been changed before.
  3. Open the phone's back cover and check if the battery is very old or not.
  4. Check the phone sticker where you will find information about the phone like; Country the phone was made, phone model, imei, etc. Quality of the phone sticker and the way the information is printed also counts.(Note that Nokia phones made from Germany, Netherlands, Finland and Hungary are usually good phones. But you still need to check the sticker quality in case the country was just printed to convince people)
  5. Check the phone screws thoroughly to be sure the phone has not been loosed before. For some phones, you need to open the phone front case cover before you can access the screws.
  6. Put your nose on the charging port area of the phone and perceive for any burnt smell from it. Further check if the charging port is not rust, including the earphone and other parts where a device can be inserted into the phone. Do not over look dust in such areas.
  7. Insert your sim card and not the sellers sim into the phone. If possible test with maybe one or two other sim cards and see if the sim network will work with the phone.
  8. Use the phone to make a call, so as to know the strength and quality of the phone service. Likewise the clarity of the mouth piece and ear piece.
  9. Test the ring tones on the phone or play music with it, so that you can hear the sound quality of the phone ringer/speaker. If it makes some crackling noise or distortion, then the speaker/ringer is faulty.
  10. Put on the phone and check the quality of the screen. If its too bright, try to adjust the contrast and if there is still no display quality, then the screen might have been changed or its a refurbished phone.
  11. Press the keypad button from one (1) to zero (0), star (*) and harsh (#) to know if they are functioning well. Further press other buttons on the phone and also side buttons.
  12. Browse through the phone menu, check "Message", "Settings", "Contacts" and other application on the phone so as to be sure the phone does not hang or freeze.
  13. Check the Imei number of the phone by dialing (*#06#), a fifteen digit number will be displayed on the screen. Check these numbers if they are the same with the Imei printed on the phone sticker. If its not the same, please don not buy such phone, even if every other aspect of the phone seems good.
  14. For Nokia phones; dial (*#0000#) to reveal the date the phone was manufactured. Do not purchase phone that has a far back manufacture date, like; Oct, 2002
The above points might seem many, but they must all be considered before purchasing a second hand phone, because buying the phone involves hard earned cash. Moreover, over looking the above points means taking a big risk and you might be duped in the process.
Take note: When you want to buy a fairly used used phone. do not be moved by what the seller says about the quality and wellness of the phone, just go ahead and check those necessary things that needs to be checked and be well convinced before considering to buy the phone. Do not manage or overlook and lapses you observe.
I wish you all the best of luck.
on Jan 20, 2010 | Cell Phones
Head phone connectivity problem how can i solve the problem please help me please
check the head phone connector, or change it or check head phone pin or change head phone and check it.
Sep 11, 2010 | Sony Ericsson W550i Cellular Phone
MY samsung jet (no network
try to do these steps:
1. switch off your phone, remove battery, sim and memory card.
2. reinsert your battery and switch on your phone.
3. on your keypad menu type this code to make a hard reset. *2767*3855#
4. after hard reset, reinsert your sim, battery and memory card and check.
you may also want to try these.
1. remove your sim and have it check with other phone if it's receiving a signal.
2. insert another sim to your phone and check if it will receive a signal .
3. check your phone profile settings, press menu, select settings, select phone profile, select normal mode and check if it will give you a signal.
if you found out that your sim has defect, you may buy new sim and replace it, but if your phone has the problem after all of the above steps, go to your nearest samsung service center and have it check. if it's still under warranty, you may want to consider returning it your phone dealer, where you bought it, and have it replace with new one.
good luck and take care...
Jan 11, 2010 | Samsung Jet S8000 Cell Phone
Phone has no dail tone
if u have more than 1 phone in ur house check that their all hangup check all ur phones wires and the main telephone line if all that is checked and still have a problem i would recommend calling ur phones manufacture
May 28, 2009 | GE Lands Phones
My phone stopped working. I checked the battery
Check that the base station has power and then place the phone on the cradle on the base station for a minimum of 20 seconds this will reregister the phone security code. If the phone does not start charging or the base seems dead then check that the power pack for the base station in plugged in and turned on.
Apr 13, 2009 | GE 25952EE1 Cordless Phone
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
