Question about Dynex 32 in. LCD Flat-Panel HDTV
<!-- from fixya rte -->How do I replace the control timer board - Dynex 32 in. LCD Flat-Panel HDTV
    Top Expert:
  • Dynex Master
  • 74,251 Answers
You have to open the back cover of the TV; to access this board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Posted on Dec 08, 2014
Model 596.66952401 I need too order a timer for my fridge where is it located so i can replace it?
Your model has the timer built into the main control board. See item location 5 in photo=> HERE
Part number=> Main Control Board WPW10503278
APPLIANCE 911
Mar 08, 2016 | Kenmore Refrigerators
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
TROUBLE REPLACING OEM TIMER - UNIVERSAL ELECTRONIC FAN TIMER
Hi, you should be real close with the universal timer and the factory OEM. On the new control board, if you have 24 volts to the board, you should have 24 volts from R to ground or to Common. I know that on most all control boards the voltage in is 120volts as you will have terminals for L-1 and L-2 to run the high voltage controls from the board and all of the thermostat control terminals in a row, R,G,Y, W, C, and so on are 24 volts. 120 volts is stepped down to 24volts control and you say you have nothing out. Make sure you have 120volts in. You are calling this a timer board, is this a heat-pump defrost board with the 3 settings and pin to defrost the unit at 30,60,and 90 minute times? This is what it sounds like. If all was terminated per diagram, you would have the 24 volts required to fire this unit. These defrost timer boards require high voltage to them as well. Even though the board is a new board and you know for a fact that it is wired properly, it may be a defective board. I have seen this many times in my years as a tech. I have shorted new boards out by static electricity and by mis- wiring one. You can kill power and look at the back side of the board to see if this has happened. Sometimes you will find that they missed a solder point on the back side not completing a circuit through the board. To give you more ideas, I would need to see the diagram, or if you could send me the model, serial, and name of your unit. The board number would help also. Check out what I have said and get back to me on this. I will wait to hear.
Shastalaker7
Jun 06, 2010 | Heating & Cooling
Washer will not change cycle
HI. This will be the result of a failed control sector. Your control sector is responsible for the sequential actions of the cycle. If this sector fails to initiate in sequence, you will experience this type of interruption. The control sector can house a timer, or a control board. The timer can mechanically fail if the motor that advances the dial plate over the cogs, becomes faulty, and breaks down. Timer motor failure is common, and will require you to have it replaced, asap. It is not repairable. If your unit is equipped with a control board, this device can fail as well. The control board can experience circuit failure, thus, promoting program failure, due to chip set faults.
In any case, the control sector must be replaced, asap. Once you have replaced either your timer, or control board, the unit will return to its normal operating status.
Dec 31, 2009 | Estate TAWX700JQ Top Load Washer
Dishwasher wont go through the cycles
Hi. this will occur when the timer control or control board has experienced a major fault within the circuitry. in most cases, the actual timer mechanism will fail. this will stop the forward advancement of the wash cycle.
Total replacement of the timer control module or control board will fix this issue.
Jul 19, 2009 | Dishwashers
Dishwasher sticking to one cycle
HI, this will occur when the timer module is malfunctioning. the timer module will need to be replaced asap, if possible. the mechanism has failed.
This applies to the newer model with control boards as well. the timer module and, control boards are principal initiators of the entire wash cycle and, if in anytime, they fail to advance the cycle properly, they must be replaced.
Ge profile dishwasher runs for hours
HI, this will occur if there is a major control fault in the timer module or, main control board. Depending on you model, you will need to replace the timer or, control board in this case. this will fix this issue
Jul 15, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Heatpump defrost board
REPLACE THE BOARD IS BAD ALSO CHECK FOR 24 VOLTS FROM COMMON AND RED TO MAKE SURE THE BOARD HAS 24 VOLTS.
Jul 01, 2009 | Icm 302c 302 Heat Pump Defrost Timer...
Timer
check the pin connector between the touchpad & control board and ensure that it's seated correctly in the slot on the control board. if this does not solve the problem replace the control board.
Sep 10, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Defrost timer board for mzd2766geq
Defrost control board is in the top of the refrigerator behind the two levers that control the temperature. You have to take off the plastic cover. There are two screws and then you slide to cover to the side to remove. The board is in a white plastic housing.
Aug 15, 2008 | Maytag MZD2766GES Side by Side...
Dynex 32 in. LCD Flat-Panel HDTV Logo
44 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
