The control on one side is flashing F2. How do I correct that?
SOURCE: my dual control sunbeam electric blanket flashes
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
SOURCE: One of the controls will not turn on. The cord is
Try swapping the controls and see if the problem stays with the control or the blanket side. In any case I would go on line and contact Sunbeam, they are a very reputable manufacturer and I would be surprised if they do not stand behind the product. You will be able to tell them if it is the control or blanket. If the other side of the blanket gets warm when you switch the controls it is the control if the same side gets warm it is the blanket. If neither side gets warm is is the blanket and control.
Good Luck,
Gilshultz
SOURCE: Sunbeam Electric Blanket Model 972 A5 Type 692
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
SOURCE: My two year old sunbeam
Here is a link to Sunbeam.You would definitely need to contavt them about warranty issues.Good luck,Greg
https://secure.sunbeam.com/ContactUs.aspx
SOURCE: need replacement control for sunbeam electric blanket
Take a look on amazon for it. here: Finally charging for our multi device world. I hope this helped you.
Simon
