<!-- from fixya rte -->My QHM495LM webcam,s mic not work properly - Computers & Internet
The receiver cant hear the sound but i hear the caller
This is fault on the MIC within the unit. Now uninstall the driver software, remove the webcam and then reinstall the drivers once again.Now connect the web cam and open the properties settings on the webcam . check for normal settings . If the fault repeatsthe webcam must be rechecked on another PC. Take opinion to consult if the webcam is under warranty
Oct 28, 2011 | Manhattan Mini WEBCam
Person I'm calling cannot hear me
It says your mic is not working... or it might be disabled...
Check whether your mic is working properly or not by typing "sndrec32.exe" in the run box(found in start menu)....
record your voice in that application and check if it works...
Jan 22, 2011 | Logitech Webcam
Friend can not hear us via Skype
If the mic is really been muted, do the following:
Start -> Control Panel -> Sounds and Audio Devices -> Voice [tab] -> In Voice Recording area press "Volume..." button -> check if "mute all" is unchecked and adjust the slider to proper position
Jan 27, 2009 | Logitech Quickcam Chat Webcam
Pc Mic and web cam help
No, you don't need to do anything more. That should do it. Logitech also has a webcam with a built in mic that would work for you as well.
Cheers
Jan 04, 2009 | Microsoft LifeCam VX-1000 Webcam
I bought a Logitech webcam and the sound won't come though. It states my input level is not high emough but I can't find it to change it please
My understanding is that a webcam is only a webcam not a webcam+mic (mic=microphone for sound to be input) unless your webcam has video and sound capabilities.
1. get a mic
2. if you webcam is supposed to be also a mic, (I have yet to see one of those myself) you should hook up the connector for the microphone (usually a a red trs plug/connector) to your pc.
3. make sure your have run the video/sound wizard of your instant message application to test your video, mic and speakers. (to see, talk and be heard and hear what the others are saying)
are you trying to hear what the other person is saying when having a video conversation?
1. check your speakers are properly connected, powered and turned on.
2. check your speakers (and mic aswell) are not muted (check your speaker icon on the system tray and check your volume controls by doing right and/or left click on the speaker icon on the system tray.
4. make sure your sound adapter's drivers are installed and your device is working properly (check device manager by going to start>run> type devmgmt.msc the press enter and make sure that under sounds you don't have any ? (no drivers) or ! driver problem for your sound adapter.
Sep 27, 2008 | Gateway Computers & Internet
No sound
try to find the setings for the mic..and chec for volume ...mute ...if it has something like call setup...also see if the proper mic is selected if it has somethig like this ..it will apear like ...your camera name ...or realteck driver ...selection ...this occures mostly when the mic doesnt have a separate jack ..but works via the same usb plugin
Sep 06, 2008 | Logitech QuickCam Communicate STX Personal...
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Mic
first make sure that you have connected the wire properly into your microphone port at the back of your system
den click start> all programs > accessories >master volume >
click options>properties>then check microphone > then click ok
then uncheck the mute button it must work now .
good luck :)
Oct 12, 2007 | Logitech Quickcam Zoom 5 Pack Webcam
Help please
check the settings on your msn that the input is set to the mic and also on the sound in control panel that input is set to labte mic
Sep 30, 2007 | Labtec Webcam Pro
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
