Question about Laser Tek Services Oki-C9200 4Pk Okidata C9200 Glossy Toner Refill Kit 4 Pack For C9300 C9400 C9500 Printers
How to reset printer model OKI C9500 to default factory settings?
I need to reset oki c9500 to factory settings
http://my.okidata.com/man-ml320-1turbo.nsf/MOCContents/029CDD66B74320C385256A6B004EE4FE
Nov 08, 2014 | Office Equipment & Supplies
How to reset printer model OKI C562dn to default factory settings?
1.Click on Start and go to control panel
2. Go to programs and then uninstall a program.
3. Find and uninstall your printer software.
4. Restart your system and install your printer.
5. Restart your system.
6. Live Happily ever after !
Aug 04, 2014 | OKI C Office Equipment & Supplies
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
Color registration problem for Oki Data C9500
Brain-storm .... simple solution .... REPLACED Magenta Drum.... works as good as usual, but is still and always been out a little - very strange, depending on the stock, if I'm using a 10pt coated stock, color registration has always been a little out ( when the cyan and magenta are being used ((together)) - purple - dark blue etc ...)
Mar 31, 2008 | Computers & Internet
Oki C9500 Printing Problem
Check the LED Head and LED Connection. The LED heads are interchangeable, BLK, Cyan, Magenta, Yellow.
Feb 15, 2008 | OKI C9500dxn Led Printer
Oki C9500 makes VERY LOUD clunking noises but prints fine...
The sound is most probably from one (or more) of the drum units. You can check by taking them out and trying to run the visible gears by hand. If you have spare drums, change them one at a time until you find the defective one.
Sep 04, 2007 | OKI C9500dxn Led Printer
Laser Tek Services Oki-C9200 4Pk Okidata C9200 Glossy Toner Refill Kit 4 Pack For C9300 C9400 C9500 Printers Logo
48 people viewed this question
Top Laser Tek Services Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Laser Tek Services Office Equipment and Supply Expert? Answer questions, earn points and help others
