It's not draining properly Pump replaced & filter cleaned what next
  • 601 Answers
If pump is new and filter is clean the next step would be to check the drain hose. This is an overlooked possibility. The pump has a lot of pressure, but if it is pushing against a wall of CLOG it will not drain. The CLOG could be lint, hair, strings, or anything else that got as far as the CLOG. You would have to check drainage all the way to main pipe. Good Luck Friend.
Posted on Nov 08, 2014
5 Suggested Answers
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
stradeteox
  • 88 Answers
SOURCE: LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Posted on Jan 11, 2009
onthejob5130
  • 640 Answers
SOURCE: Kenmore HE3t washer not working properly
ok lets see here im onthejob,,i take it that cycle stops with suds..ok first are we using he or low sudsing detergent,,,next when you clean pump filter did you check pump wires for defectives,,,try and bleach unit out to get rid of slugg...also check connection to pressure switch,,and ccu...keep me posted..onthejob
Posted on Jan 17, 2009
SOURCE: drain error still after making
LE error? Don't buy a new sensor, don't call a repairman and don't scrap it. The fix is EASY!
Turn the drum 4-5 times by hand to resettle the load, move spin speed to highest, Quick Wash, Speed Wash. It shoudl work just fine. I've had to do this a few times over the last 5 years. Why everyone wants you to BUY parts is beyond me....maybe they need to make some $$ ?
Posted on Apr 21, 2011
Drain pump
follow this steps and fix it. God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by remove back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. remote the hose and filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Jul 13, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool Washing Machine won't drain after pump is cleaned and there are no blockages
see the causes and remedies:God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
Hoses
Jul 18, 2012 | Whirlpool Washing Machines
My machine will not spin or go to the next cycle
Hi johnson_anit,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | KitchenAid Washing Machines
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
Kenmore 17379 dishes are not clean after running a cycle
Hi
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
Glasses in upper rack not cleaning
Hi
Jan 30, 2011 | Maytag 24 in. MDB5600A Jetclean II...
Dishes dont come out clean
Hi
Jan 30, 2011 | Jenn-Air 24 in. JDB1050AW Free-standing...
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
