Question about Exercise & Fitness
Have Quinton stair master no safety key is one required for treadmill to work
Will it start without key or is it required to work
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Safety keys are pretty much required for all treadmills.
Posted on Dec 10, 2014
What is the safty key
the SAFETY key attaches to the console of the treadmill usually by a magnet and is linked to the users clothing so if they fall they pull the safety key off and the treadmill automatically stops. The treadmill will not work without the safety key in place
Aug 03, 2014 | Nordic Track Nordictrack A2350 Treadmill...
Tip
How To Calibrate the Lift Motor on Quinton ClubTrack Treadmill
The following describes the steps required to calibrate the lift motor on a Stairmaster (Quinton) ClubTrack.
  1. Enter service mode on the treadmill by using the following keys at the same time:
    • Faster - Slower - Stop Belt
  2. Allow the lift motor to free spin by removing the bolts from the metal block on the jack screw.
  3. Press the up arrow on the control panel until the incline is at 5% then press the down arrow and take it back down to 0%. This will allow the lift motor rheostat to find its range.
  4. Spin the metal block on the jackscrew to allow 1 - 1.5 threads to be exposed from the top. Secure the lift motor back to the frame by inserting the 2 bolts through the bracket holes and into the metal block. NOTE: Double check the spacers on each side to make sure they are flush.
  5. Run the treadmill incline up to 15% and check the jackscrew to verify it has not bottomed out before reaching 15%. There should be around 4 - 6 threads exposed. Bring the treadmill back to 0% where there should be the same amount of threads exposed from the top of the jackscrew. If you see the correct amount of threads the lift motor is calibrated.
NOTE: If there is an error on the display panel, ex. E211, you need to manually turn the jackscrew back to 0%. To perform this unscrew the 2 bolts from the bracket securing the metal box and jackscrew allowing it to freespin. Use a shop rag or towel to wrap around the jackscrew to prevent damage to the threads. Using a pair of pliers (channel locks or vice grips recommended) manually turn the jackscrew back to 0%. Once this is accomplished run through the above steps to perform the calibration.
Quinton Treadmill Support How To Calibrate the Lift Motor
on Mar 10, 2015 | Quinton CLUB TRACK Treadmill
Why does treadmill work without the console key
Do you have another magnetic object around it? That may cause the treadmill to work without the safety key.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
Code e207 stairmaster club track
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
E207 is an error indicating "Moderate Motor Overcurrent". This occurs when either the user is out of the maximum weight range or there is excessive wear on the deck or running belt. The following link will take you to the parts and other information we have available on the club track.
Stairmaster Quinton Treadmill ClubTrack 612 612 Parts SPORTSMITH net
Jul 08, 2013 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
E203 error message when i press start button
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Quinton Treadmill E203 Error Code
Jan 09, 2013 | Exercise & Fitness
Stairmaster quinton 612 plus error code e201
Quinton Error E201 Probable Cause Grade Over Limit Fault. Turn jackscrew counter clockwise to get within range.
Corrective Action
  1. Use Up or Down arrows to bring grade into range.
  2. If error persists, replace grade actuator or VSD. NOTE: Belt and display may continue to be used during fault conditions by pressing clear.
Quinton Treadmill Error Codes E201
Mar 16, 2012 | Startrac Fitness Products Exercise &...
Is it possible to operate a Nordic track A2550 treadmill without the key? If so, how?
First thing I'd try is just using any magnet. I'm sure that's all the key is normally. If that doesn't work, no you cannot use a treadmill without a key. It's a safety measure created by the company.
Here's the key for sale on amazon that goes to your treadmill.
http://www.amazon.com/Pro-Form-Treadmill-Safety-Key/dp/B002YP4KQE
Hope this helped!
Jun 18, 2011 | Exercise & Fitness
Lost safety key
I have a Weslo Candence treadmill and I too lost my safetly key and I recently folded up a leftover valentine's card from my child's kit box and to my surprise it worked. I just folded to the size of the key and inserted and the treadmill started up with no problem. YEAH!
May 18, 2010 | Cadence Weslo 200cs Safety Key...
Exercise & Fitness Logo
231 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
