I just bought a cord for my android phone to connect to my vizio tv,but when i connect them it says no signal!!i tried all 3 hdmi inputs and they all say no signal!!what am i doing wrong??please help!!
    Problem Solver:
  • 9 Answers
Check to see if your specific Androind phone supports MHL. Simple Google search should answer that. If it is, check the connection to your phone, the cable, and the TV. If you plug it into HDMI 1 be sure to set your input to HDMI 1. Hopefully this info helps.
Posted on Nov 08, 2014
SOURCE: HDMI ON ILO 32HD
I use a Toshiba DVD Player SD-6100 and had the same problem when using a HDMI cable. The ILO TV kept saying no signal. I don't know how to make the PS3 change into sending the HDMI signal, I'm sure though that is is similar as to the dvd player simply changing it in a menu. All I had to do was use a component cable to access the dvd player menu and from there changed the video out signal to hdmi, thus sending a signal to the frikkin tv. It all works now.
The Ps3 should have a similar menu to select video signal output. Try accessing it using a previously working cable, then once changed, switch on the tv back to hdmi input and see if it worked.
Hope this helps
Cheers
CPL Avila
Posted on Nov 02, 2008
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Posted on Apr 29, 2009
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
bugoy31
  • 1238 Answers
SOURCE: no hdmi signal on a panasonic viera tv, they used to work
sounds like you need to update firmware
Posted on Jul 23, 2012
I have an asus Eee PC Seashell series netbook and I'm trying to connect it to a vizio smarttv but it keeps showing "no signal" on the tv
Have you checked these?
1. Input settings in the TV,
2. Cycle the laptop output (laptop screen, external screen, both)
Mar 10, 2014 | ASUS Eee PC 1005PE (SeaShell) Netbook
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Sreen blue, no signal floating across screen
Hello
Check all the signal cables at the backside of your Vizio for firmness. If there is any loose or bad cable connection, especialy with HDMI; will poise this problem. Check the input selection also. If improper input selection is done, there will be no signal logo will fly around.If you have selected TV instead of HDMI, when HDMI is connected and you want to see the programme, is an example of improper signal selection. Check these. OK.
May 12, 2011 | Vizio VO32L 32 in. LCD TV
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
My Vizio 42" LCD SV421XVT
U getting a non respones from ur remote or the manual side panel tv controls buttons wright.U already tries resetting it back to factory setting.But the problems still the same.Yes,the tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 11, 2010 | Vizio 42 in. LCD TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
